GE WBSR3140DW Top Load Washer Logo
Jennifer Posted on Dec 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer won't hold water, just drains to the floor.
I have a top loading GE washer Model #wwa5600galwh, I heard it spinning unbalanced and about 30 minutes later realized it was still filling up with water for the rinse cycle. Turns out all the water was draining onto the floor. I don't know where to even start looking, is this something I could fix myself?
  • Jennifer May 27, 2012
    I figured it out. While the washer was spinning unbalanced, the seal at the bottom of the tub became detached, so when the washer started to fill up again, it would just drain straight out. The washer is fairly old and never been worked on, so I've order a new part but in the mean time, I took the tub out and refastened the seal so that I can wash clothes. Was very easy to fix! I only needed a flat head screwdriver and socket set.
Nick Crnkovic
Level 2:
New Friend:
  • Expert 64 Answers
  • Posted on Dec 12, 2017
Nick Crnkovic
Expert
Level 2:
New Friend:
Answers
64
Questions
0
Helped
11452
Points
175
Sounds like there's a hole or loose ejection water hose.
Move the washer so it will run and you can look in the back to see where the water is coming from....fix the leaky problem once you find it. Could be a bad hose clamp as well
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
My GE washer #WDSR2080DEWW washer won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Ge washer won't let water spin out
heatman101
GE Washer will wash but won't drain?
heatman101
33helpful
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Will not spin,
Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required.
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is your outlet voltage low?
Check electrical source or call an electrician.
1helpful
GE WASHER SPIN OUT PROBLEMS
Sounds like the suspension for the drum is having problems - there are usually springs holding the drum up and acting as shocks - one of the springs may have come off during an unbalanced load.
Code to restart washer Duet
Answer Is the Delicate or Hand Washables cycle selected?
Maytag Performa washer immediately drains water out of the bottom
owww. you d have to remove the front panel to see what hose has split or perhaps the door boot has developed a tear. sure it will be quite obvious as to where wate ris coming form after removing the front panlel
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
