I wiped my hard drive and installed to install Linux V.11.10 oneric ocelot. Now the wireless card will not work, it says "missing firmware" while i assume this is a driver problem, i can not find the right one to install.
SOURCE: Intel wireless card unsupported - laptop won't boot
try the driver for the PRIOR version of Windows, usually it will work. The driver for 98SE/2000/ etc. may be your fix!
SOURCE: Compaq nc8000 - did fresh install of XP. Quick
Visit to the given link and see the network drivers.. there are variouse drivers mentioned on try these drivers one of them will suit your system...
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=364184&prodSeriesId=364182&swLang=8&taskId=135&swEnvOID=1093
..... Alternatively check from control pannel that.. the wireless driver has been installed there may be possibility of that the wireless button has stop functioning...
Or to select your Operating system visit to the given link...
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=364184&lang=en&cc=us&taskId=135&prodTypeId=0&prodSeriesId=364182
Hope this has helped you...
Thanks...
Any drivers that i do find, are ones that are limited to windows and will not open with linux, which im assuming is because this laptop is normaly paired with windows.
although it is a possibility that the card itself is fried, i would like to see if there is a solution to the firmware issue first, especially considering the card was working fine when i had vista installed.
thanks
