English: Hi, I have a Epson Stylus NX400 and it giving me an error "Internal printer Waste Ink pad is full and need be replaced", I has installed a CISS with a external Waste Ink Bottle at the moment to installed the CISS therefore this isn't the problem. How I can resolve this problem. I downloaded the reset utillity of Epson and running it, this unlock the printer but the error still there when I turn on the printer. How fix it?, Thanks EspaƱol: Hola, tengo una impresora Epson Stylus NX400 y me esta dando el error "Almohadilla interna de tinta de desecho llena y debe ser reemplazada", Yo tengo instalado un sistema de tinta continuo y le coloque una botella para la tinta de desecho cuando instale el CISS o sea que este no es el problema, como puedo solucionarlo. he buscado el software para resetear los contadores, lo corri y sigue dando el error. me deja imprimir pero al encenderla vuelve a aparecer el mensaje. Como lo arreglo. Gracias.
SOURCE: parpadean los dos botones el de el bote y la de la tinta
alex, te tengo malas noticias yo tambien trabajo con estas impresoras llevo 4 dañadas de igual manera, la epson en estados unidos te la cambia antes del año de garantia, es de pensar que seben que tiene su defecto que parece ser no tiene remedio, si llegas a encontara el reseteador me lo pasas yo hare igual contigo.
Hi
Normally your remedy is to replace
the "Waste Ink Pad/Pads" with a new one/ones and then reset the
"Internal Waste Ink Pad Counter". The waste ink pads are normally
housed in a black plastic box. They are located in the bottom of the printer,
towards the front, just under where the paper starts to exit. You would have to
remove the "Top Cover Assembly" to be able to get to the screw or
screws that hold that assembly in place. If you cannot figure out how to remove
the waste ink pad holder assembly [plastic box], you may need a service manual,
for the removal procedure.
Also Replace the following parts and
reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste
Ink counter and Cleaning counter.
Also check the end article at this
given link for the resolution of the problem:-
http://www.ebay.co.uk/itm/EPSON-STYLUS-DX7450-reset-Waste-ink-pad-Error-CX7450-/330584150358
Please get back to us if you have
further query else please accept the suggestion.
Thank you for contacting fixya.com
