1993 Honda Prelude Logo
Anonymous Posted on May 24, 2012
93 honda prelude distributer cap wiring diagram
I need the order of it fast. My car its not sending any spark to turn it on, i checked and the prob. is on the ignition side
  • Anonymous May 24, 2012
    I need the Diagram to put the spark plug cables in the right position.
Anonymous
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 26 Answers
  • Posted on May 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
26
Questions
0
Helped
5779
Points
79
Best bet is go to honda tech.com
    Thanks, I tried it alredy but i dont get exactly what i want. Anything else?
5 Related Answers
Anonymous
  • Posted on Oct 21, 2008
SOURCE: spark plug wires order on the distributer cap
My Honda jumps when changing gears. It has been doing this for 5 years so if it were the transmission I would think it would have torn up by now? I do not know anything about cars so someone please help me out!
Anonymous
  • Posted on Feb 28, 2009
SOURCE: 1992 Honda Accord DX will not start, gets spark, gets fuel
Same problem! Put in a new ignition switch (husband did of course!) and it worked! Very cheap, under $80.
Anonymous
  • Posted on Jun 18, 2009
SOURCE: 94 Honda Accord
my d4 is blinking also from time to time what can i do james bklyn
Anonymous
  • 2841 Answers
  • Posted on Apr 19, 2010
SOURCE: 95 honda prelude distributor cap wiring diagram
Here you go: Curtorsey About.com 7dcca7f.png
Anonymous
  • 3092 Answers
  • Posted on May 12, 2010
SOURCE: 93 honda accord ex died while driving,ran again
Check for fuel, sound's like not getting fuel.
Inserting spark plug wires to the distribution cap
Check the firing order on the cap and on the cylinders.
2helpful
Set timing on a 1992 honda prelude, 2.3 engine, I REPLACED THE DISTRIBUTER AND NOW ITS COMPLETELY OUT OF TIME, detailed instructions please
  1. Locate the service check connector and, if applicable, remove the cap. On 1988-91 Preludes, the cap is yellow and the connector is located next to the vacuum control box in the engine compartment. On 1992-95 Preludes, the service connector is located under the middle of the dash. On 1990-93 Accords, the connector is blue and is located behind the right front kick panel, under the dashboard. On 1994-95 Accords, the service connector is located behind the glove box. Use a jumper wire to connect the two terminals of the service connector.
  1. Following the manufacturers instructions, connect a timing light to the engine. The positive and negative leads connect to their corresponding battery terminals and the spark plug lead to No. 1 spark plug wire.
  2. Make sure that all wires are clear of the cooling fan and hot exhaust manifolds.
  3. Set the parking brake and block the front wheels. Start the engine. Check that the idle speed is set to specifications.
  4. Point the timing light at the timing marks. On all models except 1994-95 Accords, the marks are on the flywheel. On the 1994-95 Accords, the timing marks are on the crankshaft pulley. When the engine is idling, the red mark must align with the pointer. Some timing marks are indicated by 3 lines; the center one must be aligned with the pointer.
  1. If necessary to adjust the timing, loosen the distributor hold-down bolt(s) and/or nut and slowly rotate the distributor in the required direction while observing the timing marks.
  2. To complete the adjustment operation, tighten the hold-down bolt, taking care not to disturb the adjustment.
  3. Switch the engine OFF . Reinstall the rubber plug in the timing window and remove the timing light. Remove the jumper wire.
Fig. Fig. 4: Service connector on 1988-91 Preludes
Fig. Fig. 5: Service connector on 1992-95 Preludes
1helpful
2answers
I mixed up the firing order on my spark pkug wires when i removed
I can post an awesome diagram but I need to know your engine size...
2.2L
2.7L
VTEC
Having trouble installing leads from distributor to motor{sparks} and timing is out on honda prlude 93 h23a1
check to make shore that the cambelt has not jumped a tooth or 2.and check to make shore that the spark lead's are in correct place's so that the firing order is correct.
1989 Honda Civic hard starting and dies for no reason. Cooling fans not working. Trouble codes are #6 coolant, #10 air intake temp, #16 fuel injector. Can anyone lead me to a solution for these problems?
6
Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98 ECT Sensor (Engine Coolant Temperature)
defective circuit or unplugged / defective sensor
10
85-98 86-98 97-98 85-91 93-97 95-98 85-98 IAT Sensor (Intake Air Temperature)
16
90-95 88-95 n/a 88-91 93-95 95 88-95 Fuel Injector System
defective circuit or unplugged / defective fuel injector
check your wiring for dirty connections or broken wires, you may have wires that are rubbed through or connectors that are not making full contact. you will need an ohm meter and check wires for continuity. a wiring diagram will be needed.
Spits and sputters only at low rpms
electrical issus. have you ever replaced the spark plugs and wires? distributer cap and rotor? might be time to do this routine maintenence.
2answers
My 1993 honda prelude was recently stolen, and it has some issues
hi,
hummm, lets see here. you had plug wires stolen and you put new ones back on the vehicle. sounds like you may have gotten the firing order out of place. for a 4cyl the firing order will be 1-3-4-2. so as you look at the distrubutor, # 1 cyl should be going to the plug closest to the drive belts. and then 2 next and so on....
the way to tell where #1 cyl on distrubutor is.. "bump" over the starter until you see a white mark on the belt pulley line up with the marker on the timing belt cover. when you get that done. remove the distrubutor cap and look at which plug wire i's pointing to... it should be #1.... if not you have a firing order problem, (check all other wire orders... ) start with that plug wire being # one and then next (don't remember which way this engine goes clockwise or counter clockwise) but make sure the next in line is 3, and then 4, and then 2..... got it? ...... good luck and hope this helped.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
