Garden Logo
Posted on May 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Troy built mower honda 160 engine oil leak around governer shaft. no oil seal but shows one on parts breakdown. Can not find part number for shown seal.
Used mower was over filled with oil by local talent. Oil leak around governer shaft. Parts department said that engine serial number does not have oil seal where engine is leaking. Called a Honda tech and all he would say is that if it leaks there, it was over filled. Help
Mike Carew
Level 3:
Master:
  • Master 969 Answers
  • Posted on May 24, 2014
Mike Carew
Master
Level 3:
Master:
Answers
969
Questions
0
Helped
263362
Points
1732
Drain oil from mower until proper level. Remove spark plug and pull starter rope several times to blow out cylinder. Spray starter fluid in cylinder pull rope several times to clean out. Replace fouled plug with new spark plug. Remove air cleaner, ensure no oil present, replace filter as needed. Clean air filter box with carb cleaner. Install new air filter reattach filter cover. Prime engine, pull starter rope 1/2 way 4 times to help prime, then pull starter rope fully up to 10 times to start.
4 Related Answers
Anonymous
  • 15 Answers
  • Posted on Apr 23, 2009
SOURCE: oil drain plug
Drain plug is not necessary. Remove the dipstick and tip the mower to the side the dipstick is on and use the dipstick tube as a drain.
Stephen McGuinness
  • 143 Answers
  • Posted on Jul 03, 2009
SOURCE: my lawnmower is only 10 months old and has
Could you have hit something very hard with the blade while cutting? This could cause the shaft to bend and damage the seal. I have never heard of a 90 day guarantee, seals normally last for years.
cxbxr_3
cxbxr_3
  • 12 Answers
  • Posted on Aug 12, 2009
SOURCE: Honda Self-Propelled Lawn Mower leaking oil?
It is toast you fried the crank/connecting rod, by running it low on oil.
Its hard to say what caused the oil leak, but now it is ruined.
Anonymous
  • 760 Answers
  • Posted on Jul 26, 2010
SOURCE: oil leaking from the box on the rod that connects
No that should just be your transmission for self propelled. Most likely belt driven off motor, with level connected to cable to select drive. . Probabaly a seal leaking on the driveshaft. You could either try and replace seall or replace transmission
Snowblower blowing smoke
probably oil seal or weak gasket engines build up pressure if theres a weak spot on gasket or seals it will find the spot .it can also be the pcv valve ,pollution control valve
Dec 15, 2013 • Troy Garden
Governor pivot shaft leaking oil
over filled or bad seal. or someone tilted over engine, 90 degrees. or more.
Leak oil from underneith where the shaft comes out of the engine
If you look at the bottom of the engine, if you see oil on the large shaft coming out of the engine where the blade is attached, the PTO or crankshaft seal is leaking. It can be replace without taking the engine apart, but you'll need to remove the blade and adapter from the crankshaft, which can be difficult without the proper tools. You'll also have to remove the old seal, with a seal puller, or by using a couple self-tapping sheet metal screws into the outer metal part of the seal. You then would pry on the screw heads to remove the seal. Replace with a new one after cleaning out the bottom of the crankcase. Clean the PTO so that the new seal is not damaged as it is slid into place. You can use a length of plastic pipe to drive the new seal into place. Replace adapter and blade. Check oil level before use.
Oh, be sure it is not the drain plug, as it may have been left a bit loose if the oil was recently changed.
tom
2helpful
Beater hard to remove...oil leaking out of the place where you insert the beater
The agitater shaft that the beater attaches to is bent and needs to be replaced. It's easy to do . You should replace the shaft , pin, and seal above it. You may also want to replace the part the shaft mount through, to stop oil leak. You can google the model number and find a parts breakdown for the part numbers .
I own a troy built self propelled mower with a Honda GC160 engine. I'm wanting to drain the oil and am looking at the engine where the manual says there is an oil drain plug, but there is no plug. Can you...
it's on the same side as the muffler near the bottom of the engine. carefull with the oil if you run it before you change the oil as it will be HOT!!!...good luck
2answers
How to change the oil in my troy built pont where is the drain plug
Not sure what a pont is, or what motor you have, but on some of the Troy built small engines from Honda the geniuses designed the motor with no drain plug. You have to tilt or flip the engine over to drain oil out the filler
Feb 24, 2010 • Troy Garden
1helpful
2answers
I have changed the air filter and bought a new spark plug but my troy built with Honda 160 cc engine will not start.
there is a possibility the c oil is bad, pull the plug and with wire attached pull cord to see if any spark
1helpful
2answers
I need a new motor for horse model, serial no. 360331. which models fit this troy built.
Just about any engine with a 3/4" horizontal shaft that is internally threaded on the end and has the four bolt mounting pattern around the shaft will work. I have gone to Harbor Freight and purchased their 6.5 H.P. engine that is a Honda clone and it will work fine and only costs $100-150 dollars. The only difference is that it uses a metric bolt to hold the pulley on the shaft,the four mounting bolts are metric and you have to disconnect the low oil shutoff or the engine will die when you are tilling deep. It is a good low cost option for the Horse tillers.
Frank
Top Troy Garden Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Troy Garden Expert? Answer questions, earn points and help others
