I am working on a Lexicon MC12HD for a contractor who is a client of mine. The unit is out of warranty. The problem is that it will not power up. I looked inside and did not see any obvious fuses, although the power supply is not easy to see, and it is not clear how one would remove it to get a better look. Lexicon is very tight with support info. Anybody have any suggestions?
SOURCE: Looking for a Power supply
If you change out the electrolytes caps on your power supply it will fix the problem, or you can buy a new one at www.partstore.com
SOURCE: AOC Envision L32w761 TV. Lightning
If you are certain you have a lightning surge, almost anything can take down your TV. First check the obvious, do you have power coming out of the wall. Is the surge protector good, if you used one? If you have answered yes to the these questions, you may have acquired a power surge in your TV. You may not find it in your TV. As I have said it may be anywhere in the TV. You will need to take this TV to an authorized service center. It would be difficult for anyone out side a technician to find the problem. Thanks for asking and show all hands of support!
SOURCE: No power and no glow
Good day!!!
That problem is usually have 2 causes..Its either power supply board or mainboard..
Please take this steps on how to determine the problem:
Hope thissolution will be helpful..
Thanks for using fixya...
SOURCE: Helleo I've got a
Good day!!!!
That humming is not cause of main board..it is usually cause of faulty power supply board..
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
Hope this solution will be helpful..
SOURCE: Sanyo DP42647 tv won't turn on.
sanyo LCD tvs recieve the on command from the main board so chances are the main board was also damaged
