Mattel barbie 2005 jeep has two 6 volt batteries. most of the wiring is completely corroded. we wired it up very basically and all still works. but tried to run two 6 volt batteries in series ended up with lots of smoke and sparkes. this jeep has 2 spot lights at top two seats with belts and a plastic grill mesh wind screen side mirrors good luck
When you mean wired in series you mean you tied the positive from one battery to the negative of the other. That will put 12 volts into the system. Is it supposed to run on 12 volts or 6 volts? If it is only supposed to be 6 volts you should wire the batteries in series. Negative to negative to negative wire to load. Positive to positive to positive wire to Load. Hope this helps
