Archos Clipper MP3 Player Logo
A
Anonymous Posted on May 23, 2012
Write protection on archos clipper mp3 player
4 Related Answers
Anonymous
  • 1456 Answers
  • Posted on Nov 14, 2010
SOURCE: My archos clipper mp3 player only makes a beeping
Hello
Try rebooting the device. Hold the power button down for 15 seconds. Then turn the 504 back on. If that does not fix the problem, then reformat the drive. Back up all your files to a PC and go to the "Settings" menu, then select "System" and "Repair" and "Format tools."
Anonymous
  • Posted on Dec 31, 2009
SOURCE: how do u charge archos clipper mp3 player using
just attached the usb cable to mp3 player and put in2 computer to charge for couple of hrs
Anonymous
  • Posted on Dec 20, 2010
SOURCE: I have just bought an
I have the same problem when I try and copy tunes from my Mac. If you go into the archos file you can see them but cannot play them. How did you solve it?
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Aug 30, 2011
SOURCE: how do i download music on archos clipper mp3
Hi cotterb...
Downloading Music to your MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Please take time to rate me
3helpful
How do i download music on archos clipper mp3 player
Hi cotterb...
3helpful
If somone got a archos clipper how would they know how they work it
Start by downloading the manual from the manufacturer's web site at
http://www.archos.com/support/download/manuals/Clipper_EN_FR_DE.pdf
I have just bought an Archos Clipper mp3, I have drag and dropped music from Itunes to the Archos folder which comes up onthe desk top after pluggin it in, the music then copies across and is in the archos...
1helpful
My archos clipper mp3 player only makes a beeping sound. It does not play anything. Not only that, I can't even turn it off. I have this constant red light flashing. I have tried resetting it but it...
Hello
My clipper will only make a sound that sounds like this 'beep beep beep' please can somebody helped me
I had the same problem, beep beep beeeeep. Take all your music from mp3 player to a folder in your PC and transfer it back to mp3 and that should do it
Can't get it to play
you are downloading music format that is no compatible with your player. at the back of your player, is written the type of format that you music player supports. download files of that format into you MP3 player.......try MP3 file format.
2helpful
How do u charge archos clipper mp3 player using usb cable and how do i remove batteries
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
