Hisense tv i have a hisense lcd tv with built in dvd player, the stand by light comes on and when the on botton is pressed the blue indication light comes on, the hisense logo comes on the screen for bout 3 seconds then the screen flash's abit brighter and goes dark. if left on for awhile the blue light flickers and the on/off botton does nothing. any ideas what it might be and where i can get parts.
The problem with these poorly made (in my view) sets is they are made in China and the company there has gone out of business by my count 2 times---they make poor sets for export and no parts or service literature so when you replace it consider another brand and something worth being repaired.
The unit has a fault on its power board and sustain board. It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Main board is probably bad or the power board is not powering the main board. Common problem with Hisense tvs and their customer service is lacking if under warranty. My hisense chromebook has been dead for almost 2 months...still waiting on a return authorization for warranty repair.
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
Hi, It is entirely possible that a couple of conditions could exist.
1) the DVD may support progressive output and the TV may not
2) the TV input could be defective or the DVD output could be defective.
Possible tests are -
You could test the TV input by substituting the dvd with another appliance known to be working (say a VCR. etc). the Y input (Green) on the TV only needs to be supplied with a composite output (yellow plug). If you see some sort of response from the picture then you can confirm the tv input is at least working.
Alternatively, try a different input/ output combination between your DVD/TV (Composite signal)
Even though this problem is a year old, I thought that I would share my solution for Remote codes for a Verizon FIOS.
I tried asking Verizon, and Hisense for a code that would work as the published codes did not work to program my Verizon remote. No answer from either.
I accidently discovered that the codes listed for LG worked, in fact the first code listed worked. I surmise that Hisense uses the same codes as LG.
If you are at wit's end then try the LG codes.
By the way. I tried stepping through all codes several times but no success with the Verizon instructions. The fact that the LG codes worked, indicates that the Verizon solution is wrong.
