Cars & Trucks Logo
nathan dalton Posted on Jun 17, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 2011 dodge 3500 cummins smokes when cold started? when started first thing in morning only around 0 blows lots of white smoke smell like unburnt diesel and shakes a bit for 10 to 15 min has had piston rings, injectors, head, a few head gasket all replaced already still does not start right after sitting overnight seems like cylinder six is missfiring when capped of does not smoke. does anyone have anyother ideas of the cause of all the smoke thanks
richie46
Level 3:
Top Expert:
  • Dodge Master 12,962 Answers
  • Posted on Jun 17, 2017
richie46
Dodge Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2941681
Points
58151
Black smoke is excess carbon, blue smoke is oil burning, white smoke is water/steam. Is your coolant level ok?
2 Related Answers
Anonymous
  • 257 Answers
  • Posted on Jul 21, 2009
SOURCE: 2000 TDI - Lots of white smoke at cold start.
Sounds like your injection pump timing is off, an injector is leaking or a bad seal on your IP.
VW dealers have a horrible reputation when it comes to TDI's. Check out the posts over at www.tdiclub.com Those guys are very knowledgeable - and the first thing they'll tell you is don't take it to a dealer.
You can probably find someone in your area that has a copy of Vag-Com (scantool software that vw uses) software that could look at your timing. It definitely sounds like your dealer was throwing parts at your car because they didn't know what your problem is. If I were you, I'd copy and paste your post from here over at www.tdiclub.com
Anonymous
  • Posted on Feb 02, 2012
SOURCE: 2005 Dodge 3500 Smoke (Blow-by)
I have a 2005 dodge 3500 and i can see smoke sometimes when im driving and when i open my hood and open my oil cap while my truck is still running smoke comes out along with a little bit of oil... Do I need to change my pistons rings? What else could cause this problem...?
Just bought. 5.9 cummins Can`t get it to start without pushing gas pedal slightly. Runs good after warms up. Still have to give it fuel to start.
Numerous Conditions May Cause Engine to Crank But Not ...
repairpal.com > Problems > Dodge > Ram 2500
2006 Dodge Ram Laramie 2500, 5.9i liter Cummins ... I know in the old days the dodges had a way about starting up an engine and that would be where.
White smoke, rough idle at startup - Dodge Cummins Diesel Forum
www.cumminsforum.com > ... > 3rd Gen. Powertrain
Jun 5, 2010 - 9 posts - ‎7 authors I have an 06 Dodge 5.9L that has a light white smoke and rough idle when first ... 2006Ram 2500 QCSB 4x4, 3" Carli coils w/ 1" Daystar spacer, ... Still ran good tho, dispite the exact conditions you describe on Cold Start up.
Kia pregio problems
Destroy your radiator, drain all the oil, and redline this piece of junk
Won't start easily since it got cold (32degrees). It's fine once it starts
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These will help.
Thanks.
2answers
2helpful
My 94 ram 3500 cummins diesel is blowing alotttt of white smoke and i changed the fuel filter and did a compression test to see if it was the head gasket. it wasnt either. what eles could it be?
You would think that covers it.. But,,... When you smell the exhaust, if it's coolant, you should be able to tell. It will have a sweetness to it.
It's possible it's from the exhaust system, but that would mean you recently drove through some high water(?) or you've done a large number of short trips leading to build up of condensation in exhaust. Or someone has deliberatly pushed water up the tail pipe.(?)
Any of that make any sense?
2answers
06' dodge 3500 5.9 cummins will not start unless you spray it with starter fluid and when it starts it has some black smoke and some white smoke try to accellarate and it will stay high.
not sure if it has anything to do with it but my ford diesel did the same thing and it was because my oil was low. the oil pressure ran my injectors. dont know if dodge is the same way. also my air filter needed replced. Good luck!!
1helpful
2answers
Water in fuel, ran fresh deisel and conditioner through system, still getting white/grey exaust smoke.Please help.(cummins 3500dodge 6 cylinder)
possible cracked head thou rare. Isolate the return line and pressureise coolant up to the cap rateing and look at any discharge from the return line. You have a unique issue... is the filler neck completely sealed. Do you have any enemies with access to your vehicle? Just kidding... good luck...
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
