Question about Jacuzzi Signa 6 Whirlpool JAC-B540...
Dirty filter cartridge on circulation pump for Jacuzzi J325 Hot Tub. How do you clean it?
4 Suggested Answers
SOURCE:
  • 80 Answers
SOURCE: heater pump does not turn on Jacuzzi hot tub 325
Heater operates seperate from pumps. Do the pumps come on? Pressure/flow switch turns on heater, so if the pumps work, there is an issue with the heater element, the flow switch will usually prevent the spa from running at all and there will be an error code on the control panel.
Posted on Aug 19, 2009
  • 80 Answers
SOURCE: jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Posted on Sep 28, 2009
Coastsider
  • 331 Answers
SOURCE: Jacuzzi hot tub model J-300 series with an FL-1
A flashing “FL1” display means the flow switch is
malfunctioning open, the filter cartridge is excessively
dirty or an “air lock” condition has occurred at the
circulation pump intake.
Posted on Apr 14, 2010
Hot tub pump will not start back up after cleaning hot tub
When you say the pump won't start back up, do you mean the electrical side of things and there is just no power going to the pump. Or are you saying that the pump is on but not pumping water.
I am going to think you mean the pump is on but not moving water. This is common after you clean and drain your hot tub. You have what is referred to as an airlock in your hot tub line. It is easy to remove the airlock by simply opening one of the unions near the pump. This will allow the air to release and water flow to begin again.
Make sure also that you have cleaned the hot tub filters, if they are dirty and reduce water flow that could shutdown your hot tub pump as well.
If it is the electrical side of things make sure your GFCI has not tripped and maybe you just need to reset this. If it is anything further on the electrical side make sure you involve a professional.
  • open a union to release any airlocks.
  • clean your hot tub filters.
  • check to make sure your GFCI is not tripped.
Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
You may have to change your hot tub filters as well and can find an assortment of filters here. The filters should be changed yearly, and cleaned monthly.
Hot Tub Filters
Jan 30, 2016 | Pool & Spa
Jacuzzi z112
What is the problem you afe having with your Jacuzzi Water Heater?
Is this a Jacuzzi Hot Tub?-- Do you have some indicator lights on?-- what color are the lights?--
Is the Circulating pump running water thru the heater element?
Tell me more!-- Let's walk thru the system, and figure it out-- Mack B
Oct 13, 2013 | Water Heaters
Jacuzzi j325 my tub is about 7 years old, I noticed the tub had no power so I checked the breaker in circuit panel and it was tripped, I reset the breaker and by the time I get back to the tub it trips...
There are several things that can cause this problem. The first is you just have a bad breaker, next is your heater unit is bad, lastly the pump motor could be bad. There is also the possibility that the motherboard is bad again.
Sep 11, 2013 | Electrical Supplies
Replaced part but error FLO1 message does not go out
FLO Codes can be a nightmare.
What part did you replace? The Pressure switch?
If so try adjusting the the pressure switch. These switches typically have a dial on the side or they'll have a spot in the top where a screw driver can be used to adjust the sensitivity.
Or:
Dirty Filters can cause FLO error, try operate the spa with out the filter cartridge it if works its the filter.
Check that all slice valves are completely open & all suction and skimmer lines are clear of debris.
Check that pump impeller is working properly.
Hope that helps
Nov 13, 2012 | Jacuzzi Pool & Spa
Jacuzzi hot tub pump. Put new pump and motor in water wont circulate but can here pump running.
Check your suction plumbing to be sure it is sealed and tight. Then force some water through the pipe to see if anything is blocking it.
Nov 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
What does FL mean on my hot tub?? water doesnt circulate but is still sort of warm...
FL could be a code for low flow. If you have no circulation this sounds like it. If your pump runs and you have no flow you could have a problem with your pump. Or if you have the tub drained then it could be an air lock, if you open the drain valve till you get water out that should fix that. Also check to be sure the isolation valves are open under the spa. I hope this helps.
Feb 07, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Jacuzzi hot tub model J-300 series with an FL-1 code. I have shut off power at box and restarted a couple of times and the circulation pump reset. Now the reset won't happen. Both pumps still operate and I...
Jan 06, 2010 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Smells like somethin died
Pour some chlorine bleach , not alot.in and let it circulate. You may want to clean the filter first.You are smelling a real dirty filter.
Jul 29, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Jacuzzi Signa 6 Whirlpool  JAC-B540... Logo
178 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
