ASUS Eee PC Seashell 1215N-PU17-RD 12.1-Inch Netbook (Red) Logo
Anonymous Posted on May 23, 2012
Asus Eee PC 1215n half screen on the right is white, the other half is fine
Turned on my netbook to find the right half of my screen is dead. The left half is fine and works perfect. The right half stays white. The screen back light works fine though, I could still dim or bright the whole screen. Any idea on this issue?
  • Anonymous May 23, 2012
    When I plug the netbook to my HDTV, everything shows up fine.
Anonymous
Level 3:
  • ASUS Master 6,771 Answers
  • Posted on May 24, 2012
Anonymous
ASUS Master
Level 3:
Answers
6771
Questions
0
Helped
1779017
Points
21413
The LCD screen in your laptop is defective, the only option is to replace. Go to www.ebay.com Type: make and model of laptop, refine search to screen.
2 Related Answers
hothawk
Matson Kurian
  • 175 Answers
  • Posted on Jun 30, 2011
SOURCE: ASUS Eee PC seashell1005HA-PU1X-BK Netbook-blue..Problem
Problem is due to a CD/DVD in your system or it can be your operating system is corrupted or some other not resolved application is running behind and your computer is wating to get a return result.....
Roy young
  • 265 Answers
  • Posted on Aug 25, 2011
SOURCE: I dropped my Asus Eee
Hi ,
Yes , replace the screen , theres nothing you can do ,,,,Sorry Goodluck Roy
Bootmgr missing
Google: Hiren's boot cd 15.0
Download the iso, extract to disc. Run the disc.
At the main screen, use the up and down arows to select the "fix bootmgr is missing"
Blown IC?
Just google ASUS EEE PC 1215N Laptop DC Power Jack Connector, a lot of vendors sell these separately.
How to repair red screen on asus eee pc sea shell
Remove any discs in the computer.
Hold the power button down until the computer turns off.
Press the power button to turn the computer on. If this doesn't work, proceed to step four.
Remove the battery and unplug the netbook. Wait 30 seconds.
Reinstall the battery and plug in the netbook.
Press the power button for ten seconds. If this doesn't work, proceed to step 7.
Insert the end of a paperclip into the reset button to reset the netbook.
The reset button is a small hole that usually appears next to the USB and other ports.
Windows 7
Create a new Notepad file.
Type this code:
taskkill /F /IM dwm.exe
Save the file as displayfix.bat in the following location:
C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
Restart your computer.
hope this helps
I recently updated this netbook using the Windows 7 upgrade and went through the entire tech support call with Microsoft regarding accurate procedures to upgrade from xp to Windows 7. The netbook worked...
To let you know one FACT....
MS tech support is JUNK....
If you still want to use them it's you call.....
Solution
Get an external monitor and fix that to the monitor port (watch this video)
http://www.youtube.com/watch?v=J7MZ23T-NRg&feature=fvw
on the back or on side of the notebook serial port
if display on monitor is ok then there is some issue with you laptop display
if hardware is the issue
you need to aproach a tech shop to fix the issue
OS upgrades dont spoil hardwares....
Horizontal white lines on screen on ASUS netbbok
This is symptomatic of battery problems at a vague guess
1helpful
Switched on notebook, and screen appears broken,
Hi there.
Yes you can have the screen replaced and you can do it yourself, however i would recommend that you send it for repair as these Eee PC's are difficult to disassemble and you have to know what your doing.
If you have any of the manufacturers warranty left on the netbook take advantage of that and send it to Asus for repair.
Good luck and thanks for choosing FixYa!!
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
