My lexmoto tournado 50cc scooter has started for the first 8 months i had it first time but for a week now it has been taking me about 2 to 3 mins to start it all the time it is really getting on my nerves please can some one help?
Get a better spark plug and oil change with good stuff
Your carb is not sending enough fuel to the cylinder, or your carb is not getting enough fuel. So either the fuel filter is clogged, the carb itself needs to be taken apart and cleaned with some carb cleaner. Also replacing the spark plug will also help with starting issues.
SOURCE: 2007 50cc moped.wire with the fuse getting hot
Check the whole system over an see if evory thing is fastened securley,make shure that no two wires are toucing!
SOURCE: hello i have a longia 50cc scooter
. i suspect the choke has a short in it or a bald spot on it and when it kicks in it draws power from the cdi unit also make shure the wires are not reversed on the choke i would check that first
SOURCE: hi have a yiying 50cc moped and it keeps cutting out and its slow
take it for a full service, clean it, check your brakes r not to tight, check all your oil levels, clean your ait filter ( all done in ur service), check your bettery isnt flat, all that kind of **** n hopefully it will be a smooth runner again
SOURCE: moped
the gapping is standard you can u a match book and if it slides between the gap easy it is fine if it wont goo in the gap it needs to be gapped more if there is alot of space between it, it needs to be closed up some.
