When I plug in the Bose 321 the front panel lights up with Bose 321 then shuts down and won't do anything else. If i unplug it for a minute and plug it back in it does the same thing.
Https://www.techwalla.com/articles/how-to-reset-bose-321-gs
This may be of use.
SOURCE: bose 321 have dvd picture but no sound HDMI
check the power suply behind the acoustimass set to 115v, not to 230, that will solve you problem
SOURCE: I have a Bose 321
That is indicative of a main board failure in the Bose unit. I have seen this way too many times.... when these Bose 321's go they really go. It will need to be repaired if you want to salvage that system, there is nothing you are doing incorrectly, and nothing you can do to reset it, it is true hardware failure inside the unit. Your best bet is to call this "back-end" number of Bose's to set up the service, 1-877-210-3782, they are open Monday - Friday: 8:30 AM - 8:00 PM ET...
So sorry about that, but it definitely is a failed board in the unit.
Tim
SOURCE: Bose 321 won't turn on
I'm amazed at the range of comments regarding this system; they range from unbridled enthusiasm to some **** words.
Before I try to help, if I am not familiar with a specific model but have a clue to what the nature of the problem might be, I research the item to see if I find some support for my suspicion.
You might keep tabs on some comments I found relating to a possible class-action lawsuit due to the array of problems that have appeared with this system.
This link will give you a sample of them:
http://www.amazon.com/Bose-DVD-Home-Entertainment-System/dp/B0002JY6SQ
SOURCE: Bose 321 II dvd drawer won't open, fixes here
Hi Donna,
Please do be frustated.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage).
If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
Best luck,
Jay
Hi me robin my bose turn on show 321 and then turn off. What wil I do pls help me
I have the exact answer you are looking for
am using bose 321 series 2 home theater .yesterday when i turned ON .it won't turn ON ..power not came ..give some soultion ..power cable working good ..
