Question about Nintendo Wii Fit - Balance Board + Game Console
How to configure gameon balance board with wii console
I was given a wii console with a gameon balance board. I haven't been able to sync the board with the console. Can anyone suggest how? Thanks!
    New Friend:
The sync button isn't in battery compartment of gameon it's a little black button on base of board..I used a nail file to click it down and hold sync button on console...screen goes ping it's all done
Posted on Mar 10, 2018
    Sergeant:
  • 220 Answers
1. You need to put Balance Board compatible game disk in the console.
2. Select Disk Chanell and press Start
3. Remove SD Card slot cover on the console and the battery cover on the Balance Board
4. Press and hold for 2-5 sec the SYNC button on the Balance board. You will see a blinking light.
5. Press the Sync button on the Wii console and after a while you will get non-blinking light.
This will mean that your device is synchronized and you are able to use your Balance Board.
Good Luck!
Don't forget to close back the covers you've removed earlier.
Posted on May 23, 2012
SOURCE:
SOURCE: wii fit balance board
You need to sync the balance board with the console. Instructions are in the manual. Sync button for board is in battery compartment and sync button for console is in panel under reset button.
Took a few tries for me, be carefule not to hold sync button on console down for longer than 10 seconds because it will deregister all wii remotes.
Posted on Dec 23, 2008
SOURCE: Can't sync wii remotes to console
When you sync the wii motes you have to do it in proper order!!!
There are 2 ways to sync one is minor out of sync stuff. You push red button on the wii briefly then quickly press the red button on the wiimote.
Second one is what you need to do. First remove any disk then hold in the power button until the light turns red. (not yellow or orange). Release it then unplug the Wii. Do not remove the batteries but if they are low replace them before you turn it back on. Wait at least 2 minutes.
Have the backs off the Wiimotes.
Plug the Wii in.
Turn the power on.
As the Health and Safety screen appears push in the red button on the Wii.
Hold it there a min. of 15 seconds. 25-30 is better.
When you release it right away push the red button on the first Wii mote. It flashes all the lights.
Immediately press then release the red button on the Wiimote while lights are flashing. When they stop flashing it will be synched.
a.Then press the button on the Wii again (this time only hold for 2-3 seconds) then press the red button on the second wiimote and while lights flash press the button on the Wii again.
Repeat a. for any other wiimotes.
Posted on Feb 15, 2009
  • 20 Answers
SOURCE: I can't get my wii balance board to sync with my
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk17
Posted on Jan 08, 2010
  • 155 Answers
SOURCE: wii fit plus keeps asking me to sync the balance
I'm afraid the only way to play Wii fit is to use a balance board. That's why it wont let you past.
Posted on Mar 31, 2010
  • 85 Answers
SOURCE: Turn off wii balance board
With our board it goes off just fine leaving it alone, maybe something is stuck on it try removing the 4 bottom legs covers and just leave it be a few minutes if that dont work just take the batteries out and find a safe place to keep them for future use. Find out if your board is under warranty and return/exchange it?
They are sensitive so just be patient :P
Posted on Apr 27, 2010
How to connect the wii
Open the battery cover of the Wii Balance Board, you'll see a red "Sync" button. On your Wii itself, if you lift the SD Card slot you will also see a red sync button. Press the sync button on both the balance board and the Wii and it will connect.
Jan 11, 2012 | Nintendo Wii Fit Plus Red Game System...
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
When i click the button on the wiifit board to connect to the wii, it connects at a second. then loses connection and wii says it is lost. the button on the board just keeps flashing or goes off
If you haven't already tried to replace the batteries, do this (if you have, this is useful information to include in your problem description :D). If that hasn't worked, you may need to re-sync the board with your Wii.
1. Power on your Wii console (there is no need to power on your balance board at this time).
2. Open the SD card slot cover on the front face of your Wii to reveal the red Sync button on the Wii.
3. On the bottom of your balance board, remove the battery cover to reveal the red Sync button on the balance board.
4. Press the Sync button on the balance board (there is no need to keep it depressed; simply press and release). You will notice the power LED on the power button on the balance board blinking.
5. Now press (and release) the Sync button on the Wii console. After the LED stops blinking, the Sync is complete.
If this does not fix your balance board, it may need to be repaired or replaced. Contact Nintendo and provide warranty information if applicable.
May 04, 2011 | Video Game Consoles & Games
How can i re connect the wii fit balance board to my wii ?
Synching can be completed only if a compatible game disc is running in the console. Compatible game discs (such as Wii Fit) will display the Wii Balance Board icon on their packaging.
The Wii Balance Board must be synced to each compatible game individually.
Follow these directions to sync the Wii Balance Board (so that it is recognized by the Wii console):
Insert a Wii Balance Board compatible game disc (such as Wii Fit) in the Wii console.
Mar 16, 2011 | Nintendo Wii Console
How do you sync the wii console and wii fit board
Put the Wii Fit game disc in the Wii and start the game. Then open the small SD Card slot cover on the front of the Wii console then remove the battery cover on the bottom of the Wii Balance Board. Press and release the SYNC button on the Wii Balance Board. The light on the board should start blinking. Afterwards press and release the red SYNC button on the Wii console while the light on the board is still blinking. The light on the balance board will stop blinking and stay on steady once the syncronization is successful.
Mar 03, 2011 | Nintendo Wii Console
How do you sync the wii fit board and wii console
  • Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
  • Insert a Wii Balance Board compatible game into the Wii system.
  • Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
  • Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
  • Turn the Wii Balance Board upside down.
  • Remove the battery cover under the balance board to reveal another sync button.
  • Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
  • Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
  • Mar 03, 2011 | Nintendo Wii Console
    I can not re start my nintendo balance board,
    2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
    3. Open the small SD Card slot cover on the front of the Wii console.
    5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
    6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
    7. The blue light will stop blinking and stay on steady once the syncronization is complete
    Dec 20, 2010 | Nintendo Wii Fit - Balance Board + Game...
    We used our wii fit on another wii system. After
      Try these steps!
    7. The blue light will stop blinking and stay on steady once the syncronization is complete.
    Fore more detailed information (including pictures) on how to sync the Wii Balance Board, click here.
    If you are still unable to sync your Wii Balance Board, please call 1-800-255-3700 so that they may assist you further.
    Hope it helped.
    Nov 22, 2009 | Nintendo Wii Fit for Wii
    Wii fit balance board
    Sep 09, 2008 | Nintendo Wii Console
    Nintendo Wii Fit - Balance Board + Game Console Logo
    446 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    shevantha perera
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
