My washing machine has just started making a horrible noise especially when it gets to the spin cycle for a wash. I have had a look and it looks like the tumbler wjere you put the clothes has come away. Im not sure but it looks like it is meant to sit in the rubber seal??? any help would be greatly appreciated. Water is also leaking from beneath the machine at the front !!
The drum.........which you pop ya washing in.......hangs via 2 spring under the machine lid..........if 1 snaps........you will get more noise......and maybe water leaking via the door seal as the drum wont sit level.........
remove lid then look either side for 2 springs.......
if 1 has snapped its an easy fix.......take you about 1/4 of a hour to do.
cheers
SOURCE: LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Testimonial: "Thanks for the quick reply Ambari, that's exactly what I wanted to know. Atleast I'll some idea if the repair bloke is pulling a swifty. Cheers"
SOURCE: LG Intellowasher 7kg 800rpm WD-8074FHB
It could be that the springs have become lazy (stretched) and not supporting the spinning weight as good as they once did or as happened to me one of the shock absorbers at the base of the unit has come adrift from its securing point. Replacement parts are easily available but you will need someone strong to fit them with all that new tension.
SOURCE: i have a lg intellowasher 7kg wd-8015c (front
the water pump is sending a signal to the pcb telling it there is a fault clean the filters and wheel on the water pump
let me know how you went
sonic boom electronics
SOURCE: My LG 7kg frontloader intellowasher WD8013F is
i removed the filter off the front of my lg intello washer to clean and now it keeps leaking water from the filter what have i done ?
SOURCE: My LG intellowasher 7kg WD-8015C
Most common,Water supply okay, Door closed properly,Child lock not switched on....? Good Luck
