SOURCE: what causes j 7 error copde in xerox workcentre
by replacing the drum unit or replacing the crum the code j7 will be cleared
SOURCE: Need printer driver for Windows Vista 64 bits for Xerox WorkCentr
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=GLOBALPRINTDRIVER&ripId=&Xtype=download
You can try this driver. It may be quirky at first but it should work for basic printing needs. There is a PCL6 and post script try both sometimes it will take one but not the other. Its vista flip a coin :) -Phil
SOURCE: How do you change the toner cartridge on the xerox
You can always find your solution to a Xerox problem at the Xerox Knowledgebase.
Here is the direct link to this solution with pictures!
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=467,E=0000000002703228701,K=8434,Sxi=4,Case=obj(862)
Solution : Replace the Drum / Toner (Dry Ink) Cartridge
CAUTION: Do not use warm water or cleaning solvents to remove Toner (Dry Ink) from your skin or clothing. This will set the Toner and make it difficult to remove. If any Toner gets on your skin or clothing, use a brush to remove the Toner, blow it off, or wash it off with cold water and mild soap. If not, launder your clothes with detergent and cold water. If the fabric label says to dry clean, inform a commercial dry cleaner that the spot is Toner so that they will not use a solvent that will set the stain.
NOTE: Make sure the Cartridge part number corresponds to the machine model. If an incorrect Cartridge is installed the message 'Check Drum / Toner (Dry Ink) Cartridge Message' will continue to appear on the machine display.
CAUTION: Do not shake the cartridge and this could cause the Toner to spill.
