Question about HP Compaq Presario SR1220NX (PJ517AAR) PC Desktop
System will not power up
HP Compaq Presario SR1220NX. System was working fine. Suddenly stopped powering up. Power supply is Bestec ATX-250-12Z. Green light on back of power supply blinking fast and continuously. When power supply is disconnected from motherboard the green light stays lit steady.
  • 1 more comment
  • Anonymous Oct 15, 2008
    I had the identical problem after moving my computer and powering up.
    I found a loose mounting screw that likely had shorted something under the motherboard which is where I found it after hearing it rattling around.
    The motherboard had a missing mounting screw.
    Poor quality control on the part of Compaq!
    I suspect I will need new motherboard
    The "fix" link that the original message refered to does not open.
  • Anonymous Mar 22, 2014
    when i plug in my computer the power supply blinking green but when i unplug my power supply to computer it lights green
  • Anonymous Mar 24, 2014
    Power indicator lights very feint but with no start up - the unit has to be switched off at the back to stop
  • 624 Answers
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Posted on Jan 02, 2007
  • teresa Aug 28, 2013
    OMG I used the power suppy solution of switching voltage and my computer came right on..Tomj thank you so much for your suggestion!!!!!!
SOURCE:
Green light in rear flashing won't part up
The green light flashing is a diagnostic LED light, telling you there is a power failure.
More specifically a bad Power Supply.
Weak voltage power rail.
The Power Supply used in a Compaq Presario SR1010Z desktop computer, is a 300 Watt unit, and is an ATX form factor.
[ATX form factor for a Power Supply, denotes the size of the Power Supply case, and the shape.
It is approximately 6 inches Long, 6 inches Wide, and 3-1/2 inches Tall.
The ATX form factor for a Power Supply is used in over 90 percent of the personal computers out there, and is as readily available as the air we breathe]
Usually, HP uses one of three generic Power Supply manufacturers.
1) Bestec
2) Delta
3) HiPro
All are low quality Power Supply manufacturers.
This is HP Support, and the main menu page for the Compaq Presario SR1010Z desktop computer,
http://h10025.www1.hp.com/ewfrf/wc/product?product=1146324&lc=en&cc=us&dlc=en&submit.y=7&submit.x=6&lang=en&cc=us
If you click on Manuals, then on Upgrading and Servicing Guide on the following page, there are instructions on how to open your computer case.
This is instructions on how to replace a Power Supply, from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01356113&cc=us&lc=en&dlc=en&product=3548196
(It's for a Pavilion a6230n desktop computer, but after you open the computer case of your Compaq Presario SR1010Z, the instructions are the same)
What Power Supply would I recommend?
There are 100's to chose from.
This is but one example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276575&CatId=1078
Chosen because;
1) Maximum wattage is rated at 450 Watts.
A computer ONLY uses the power it needs, and NO more.
Wouldn't matter if you had a 10,000 Watt power supply, (No such thing. An exaggeration), if your computer only needs 100 Watts, it would only use 100 Watts.
(Surfing the internet typically uses 100 watts)
2) Has all the power cables you'll need, and more. Tie up the power cables you do not need. (Use plastic ties, Not wire, or bread wrapper ties)
3) 24 Amperes (24A) on the 12 volt power rail.
4) 135mm cooling fan.
The cooling fan on the Power Supply you have now is 80mm.
A larger fan turns slower. Produces as much air as a smaller fan, (Or more), but makes less noise.
Less wear on the fan's bearings also.
5) Is an ATX form factor Power Supply.
6) It's 80 percent efficient, compared to the 60 percent efficient Power Supply you have now.
(That is, if it was working)
Sep 12, 2010 | HP Compaq Presario sr1010z PC Desktop
How to use ATX-250-12z SMPS with 24 pin
Chances are that 250w power supply is not going to power a motherboard with a 24 pin connector, but you can try.
You will need to purchase a 20 to 24 pin adapter cable.
Google Search Terms: 20 to 24 pin adapter
Oct 27, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
I have a Bestec atx-300-12az and i need to know which power supply harness to use on a Samsung model#HD103UJ hard drive.Thanks,Tony
Technical Details
  • Samsung Spinpoint HD103UJ 1 Terabyte SATA/300 Hard Drive General Features:
  • 1 Terabyte formatted capacity 7200 RPM spindle speed SATA/300 interface 32 MB buffer
  • 8.9 ms average seek time 4.17 ms average latency 3.5-inch form factor
  • Improved recording stability over temperature with PMR
  • Advanced dynamic FOD control for best data integrity
SATA Power3 Peripheral4 Floppy5 02 +3.3V (Orange)
03 COM (Black)
04 +5V (Red)
05 COM (Black)
06 +5V (Red)
07 COM (Black)
08 PG (Gray)
09 +5VSB (Purple)
10 +12V (White)
11 +12V (White)
12 +3.3V (Orange)
13 +3.3V (Orange)
14 -12V (Blue)
15 COM (Black)
16 PS-ON (Green)
17 COM (Black)
18 COM (Black)
19 COM (Black)
20 Blank
21 +5V (Red)
22 +5V (Red)
23 +5V (Red)
24 COM (Black)', CAPTION, 'Pin Signal (Color)', WIDTH, 150, BGCOLOR, '#000000', FGCOLOR, '#FFFFFF');" onmouseout="return nd();" href="javascript:void(0);">matx24pin.gif
atx12v.gif sata.gif drive.gif floppy.gif This ATX12V power supply is a 300W, five output unit with remote on/off, and UL, CSA, and TUV approvals. RoHS compliant. Original HP part number 5188-2625 used in many Media Center, Pavilion, and Presario computers. Also serves as upgrade for HP/Compaq part numbers 5189-3964, 5188-0131, 5187-5116, 5187-6114, 5188-0129, and 410507-001. Airflow drawn out of case into surroundings by 80mm internal fan. Built-in power status LED above AC inlent. 2 x 12 (24 pin) main board power connector. Includes two daisy chained Serial ATA connectors. Bestec model ATX-300-12Z CDR, also replaces ATX-300-12Z BC, ATX-300-12Z BD, and ATX-300-12Z CC. i trust this helps
Jul 15, 2009 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
I need a new power pack (Battery) for my PC. Part
Do you mean the CMOS battery? (The little round one on the motherboard?)
In this case, you can replace the battery with a standard CR2032 lithium battery (3 volt, 220mAH rating). You get that at Walgreens, Radio Shack etc.
For how to replace the battery, take look at page 9 of the manual.
If you don't have one, you can download it here.
If you are looking for another battery, just come back here and leave a comment. I will check back and be happy to help.
Mar 03, 2009 | HP Compaq Presario SR1220NX (PJ517AAR) PC...
DESKTOP WON'T POWER UP
it is your power supply it needs to be replaced
Jan 07, 2009 | Gateway Bestec ATX-300-12EB3 305w Power...
Can't reboot Compaq/Presario desktop, (power supply is working)
If the system recovery disk doesn't work it usually mans that the hard drive is bad. I would change the hard drive and use the system recovery disk on it after replacement.
Dec 27, 2008 | Computers & Internet
Compaq dead after power company shutdown period
Sounds like a blown fuse in the psu, replace the unit and you should be good to go.
Nov 30, 2008 | HP ATX-250-12Z, ATX-250-12Z Rev. H1, HP...
No Power of a Compaq Presario Computer
Make sure that the power button is conected to the right prongs on the mother board. On the writing next to the prongs it should say power.
Feb 23, 2008 | Computers & Internet
HP Compaq Presario SR1220NX (PJ517AAR) PC Desktop Logo
1,141 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
