I think you connect t the first router with an ip address like 192.168.167.1 or something like that. If you have two routers from the same brand they could have both the same ip address.
You can check by connect the second router with a ethernet cable and log in. Before you connected the second router, you had to make sure you did change the address from one of the routers, to the same range, but other last number. That way you can reach the admin page from your computer without an extra ethernet cable.
If you are in analogue mode, switch to digital mode - usually marked as DTV on the remote. Alternatively, if you are already in digital, switch to analogue mode - again press DTV on the remote.
Some menu/setup/picture options are only available in analogue and others only available in digital. Don't ask why . . . it's stupid.
first question. you need a remote to get to the inputs on the tv. some reason they made it like that. get universal remote and try it if don't work return and try another brand ect.
second question.
try another code maybe or jsut return it and try another remote. the rca 15-2115 5 device remote i have workes with the "A/B tv?vcr". on the origional remote that comes with the tv there are actually 2 buttons. one is called "input" and the other is "game". the only difference between them is turns the game mode on and off in the picture menu. i really don't like haveing "game mode" on because it makes the picture looks bad to me. you can turn it off in the picture menu easy.
Can you ping the ip address? By default, the ip address should be 192.168.0.1. You can verify by going to Start, Run, cmd. At the command prompt type ipconfig /all and you will see the ip address, dhcp server, gateway, etc. The gateway will be the address for the router. Type ping 192.168.0.1 (if that is the address). Also, the default username is admin and the password is left blank.
