SOURCE: how do i connect my verizon dsl westell 6100 to my belkin g rtr?
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
SOURCE: how to put password on a belkin n150 router?
Well use a browser http://192.168.2.1 and log on with the word admin as password & logon. This will open up the setup for your router. Also go here to get your manual. http://www.retrevo.com/support/Belkin-N150-Wireless-Routers-manual/id/23537ag620/t/2/
Testimonial: " I think we need to talk add me up at YM [email protected] tnx "
SOURCE: Belkin wireless G desktop network card
What has happened is that the proxy server on your last internet connection is in need of being redetected. you will need to delete any old cookies and internet files, also check in the internet explorer tools>internet options>connection, that the the the last provider you used is trying to connect instead of sky, so either select never dial a connection or sky as your default connection. Also check that in the properties of the belkin adapter that obtain an ip address automatically is checked in the TCP/IP properties. You may also need to refresh your browser a few times before you get on the net. A good temp file and reg cleaner, is Ccleaner, it's free and available at the link below http://filehippo.com/download_ccleaner/
SOURCE: Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
SOURCE: Belkin router problems with RCA modem
Do a powercycle. Make sure to completely turn off the modem, router, after 30 seconds, turn on the modem first then the router.
If that will still not work, perhaps there is a need to update the software of your router.
