Maytag Washer W-12, Listed 745G, Model No LAT 8005 AAE. When washer finishes washing clothes, there is a dripping of water inside the unit where the water supply enter the washer. I do not have a repair manual. Is there a manual availble for this model, or how can I fix the leaking of water?
What has happened is you have sand in your water valve from your water. This pluggs the water valve and also sticks it open so when the water valve shuts of there is still a small trickle of water coming through the washer. Replace the water and it will fix the problem (no way of cleaning the inside of the valve.) Replace water valve.
my unit when off continues to leak water into the cylinder until it is almost full by mourning. We then have to hit the drain cycle to empty the unit.
my unit leaks water into the cylinder when not in use. We have to keep hitting the drain cycle when the unit fills up.
where can i get a valve.
where can i buy a valve
