You should watch the video on this blog. This is a very common problem, because the original gun/wand on many pressure washers is the same! However, Prism Teachings observed something that you should know about its design: http://electricreplacementgun.blogspot.com/
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
SOURCE: Karcher pistol gun has broken
Make sure you DO NOT have a check valve (this is what stops your hose running when you disconnect from the hozelock fitting) in your hose pipe system, This will send a shockwave through the pressure washer and destroy the fitting you mentioned. They can be easily removed.
SOURCE: I have a 3000 psi karcher pressure washer with
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
SOURCE: My Karcher pressure washer pulsates
your pressure bypass valve is leaking water pressure by and not building full pressure
Which model, and where exactly is the leak?
