I had/have the same printer and the same problem. I am running Windows XP.
Go to the "Control Panel.
Select "Scanner and Cameras"
You should see your device listed here. If not then add it.
Select your device and you will see "Welcome to the Scanner and Camera Wizard".
Select "next" the following three times.
It will then scan the desktop.
Select "Next" and then finish.
The red error light should be gone.
I suggest ignoring the red light unless it just drives you nuts. You may have to run this everytime you turn your computer and printer on. Some reason the scanner is not linking with windows and you have to introduce them everytime.
Keep the printer.
hi i did the scanner and camera thing but it says it can not dedeck why
