3 x A
SOURCE: Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
SOURCE: Remove bottom front panel AEG 6081
before you take the pump out, if drain hose goes into a spigot on the sink trap, take drain hose off and check hose and spigot are not blocked. this is very common.
can't remember anything special about the screws - used to be philips head but may have changed to multi-spline.the top ones are indeed obscured by the door panel but you can normally get to them with a stubby screwdriver or take the outer door panel off - just a few screws
SOURCE: Ontegrated dishwasher door fitting
Just fitted on of these & found the door very easy to fit.
The instruction sheet is actually a template as well. Attach it to the back of the door & where indicated drill 2mmø holes to a depth of 14mm. Firstly then screw in the 2no. screws that go into the door slots, the actual screws are easy to spot as the screw thread finishes approx 5mm from the head.
Once that is done you need to offer the door to the front of the dishwasher & slot it into place. Once done you have to fix the door in place with the 6no. longer screws. To do this you must remove 4no of the screws which are holding the front of the dishwasher together, the other 2 screws go through empty positions at the bottom of the dishwasher door.
To help with this process I would recommend you use a soft jawed clamp to hold the door in place whilst you screw it in place.
There are also 2no. angle brackets that fit into 2 slots on the top of the dishwasher which are then used to hold the dishwasher in place under the work top.
Hope this helps.
p.s. one last thing, the thin strip of steel that comes with the kit fits onto the underside of the worktop in the position shown, I believe this is a steam deflector to protect the underside of the worktop
SOURCE: AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
SOURCE: Antiflood system triggered-how to reset on aeg favorit 35080vi
Hello everyone. Have just fixed a problem with my aeg dishwasher thanks to this site. My anti flood switch in, so I unpluged, pulled the machine out, tilted it, wiggled the outlet hose, which I think was a little kinked and way hay it works. Thanks FIX YA. Good luck everyone. Carolyn
