What PC, the pc has service tag and a model number there.
like DV5-1234us, (crude example)
what did it come with what OS?, some HP PCs had 3 choices .
from w2000 to VISTA. (OS=op sys)
is this a new to you,old PC to you found dead, or you had it running say
for years now dead from XP virus and then decide to do the right thing and upgrade it.???? history MATTERS.
w7 successful you said why does your post contradict that.
id say id did not,
Installed how, ? (the only 3ways)
1: using the F11 key< HP restore. magic hot key reload?
2: using the correct install disk from HP? media kit. (if above fails)
3: using Microsoft disk? (it will fail, ask why) do not do this.
if you use MS disks
many HP drivers will be missing
and all HP apps and other important features will be missing.
the top fail here is the HP laptop key board top panel is dead.
the one with volumn up and wifi on/off, will be dead.
W7 fails to load.
1: the HDD is bad.... if bad the F11 key restore is dead too.
2: you failed to boot it 3 times after, it loads.
FYI if you install w7 there are over 350 updates, that can take days to load, after, do not say yes, to updates as you install or it will fail.
W7 is a pain to load, I have home made disks that slip stream the 350 updates, so its vastly more easy,
love to know who's, w7 install disc's you have.
to test an old dead dog pc, found on the road dead.
try running a LIVE LINUX or WINDOWS PE disk CD.first
see if the puter even runs ok, before investing in say a new HDD
or new OS, for $225 (hdd 100, os 125?) but no PC stated so...????
there are 1000s of HP puters made from 1984 to now.
we cant yet, guess what you have,
post the service tag,
this is a service tag , if you and gone to real HP site.
this is there 1st question, for the same reasons.
here is the REAL HP , help,
the REAL DEAL that. no spam, or other bs.
https://h30434.www3.hp.com/
SOURCE: Whenever I start my HP
That message means that your hard drive is bad and is not seen by your computer. If it is under warranty, HP will fix it. If not, you can find a hard drive for it for $70 +, depending on what capacity you purchase. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
Although the hard drive is bad, a good tech can retreive your data, ie: documents, pictures and music from it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Black screen, Blinking cursor for
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS
STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE
MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR
PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL
MODE. IF THIS DOES NOT WORK SELECT "LOAD WINDOWS
WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY
SORT OUT YOUR PROBLEM. PLS REPLY OR COMMENT. THANKS
SOURCE: My HP ProBook 4520s XT943UTABA
Is this your issue?
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c02747785&jumpid=reg_R1002_USEN
SOURCE: i cant find sata drivers
There are two ways.
If you bought a new SATA and get a blue screen when you install win. server 2003, you have to go to BIOS and change HD setting. (not on 1st page for sure. I have to what option you have.)
Or
You have to get it from HP, but I don't know whether they have or they will give you for free.
SOURCE: My HP Probook 4520S came
Best regards, i can say that it really problem, that problem with 64 bit, driver problems will be all time with printers, scaners, webcams, and other. I think will be better, if you reinstall windows 7 32 bit, for work without probles.
