System runs at only 10 psi had a hard time priming. checked wiring twice but still have concern naturally. pump is a 230/115 v i have 115v motor came prewired for 230 volt as per wirng diagram switched brown and white wires on the motor as per wiring diagram on motor. i shut down immediattely and rechecked wiring schematic again. cant figure it out, any help?
SOURCE: What change at the motor wire connection plate do
All motors are different depending on what plant they came from, when they were made and so on. The wire plate will have letters or numbers on it and the wires will be color coded and you will have a wireing diagrahm on the side of the motor. If it has been painted over a little acitone or nailpolish remover will clean it. Sorry I can't be more help.
SOURCE: I just installed a new
hi,
As you said the elecrtical connectoins made by you is correct. But the pump is not getting power from the pannel board to which you connect the power lines. If the older pump burned out then it can make some trouble to the pannel board also. Check if there is any contactor relay in the pannel board, it will be there. If so you have to check the its condacts through which the pump gets power. There is a chance of burning of the contacts of the relay when the older pump burned. If so you have to replace the relay also.
ok
