I have a 27'' symphonic tv and a new philips universal remote.....I cannot get the tv t recognize the codes or by searching . I have to manually shut off tv. The remote does work on my rca tv but not the symphonic tv...any chance the tv sensor is out ???? can that be fixed or do you recommend a different brand of remote?? I had a new rca universal and that wouldn't work either ( thought I bought a bad remote)
thanks for your help........gp
SOURCE: philips universal remote codes for symphonics tv
Try one of the following 4-digit codes:
0906, 0520, 0324, 0247, 0004
Good Luck!
One more 'lost code list' person. I have a philips SRU 2040/17 universal remote and a sanyo tv. 'code seach' doesnt work, i need the actual 3 or 4 digit code. HELP! my kid wants to watch cartoons and i cant turn the tv from video back to cable.
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
