Some of the keys on my roland creates a loud sound when i'm playing
SOURCE: roland juno-d, keys are either too loud or too
Normally you have to clean the conductive rubber "pills" AND the circuit board traces they get pressed down on.
USE ONLY 99% isoprophyl alcohol on Q-Tips to do the cleaning and be gentle.
Use of other product like deoxit and other contact cleaners will wreck the contact material.
SOURCE: Where can I take my roland juno keyboard to be repaired lost soun
juno, lovely instrument, try the synthesizer repair centre in london
SOURCE: Sir i have purchased Roland
Read pages starting with 49 in your user's manual.
You MUST format the USB flash in the GW-8 before it can be used. Formating in a computer MAY b e inadequate as sometimes the formats have special quirks.
Also pay attention to the MAXIMUM file name length... It is 16 characters MAX !!!!
SOURCE: Got a Roland GW-8. I've had
OK... It is literally impossible for the unit to "go out of tune" as it is crytal controlled... HOWEVER what is probablly happening is the PITCH BENDER is getting into the mix somehow.
If the centering on the pitch bend control is sticking or is loose, this would likely be the problem.
Do some tests with the pitch bender to see if you can detect either a mechanical or offset condition of the control.
