Televison & Video Logo
shams Posted on May 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No hd signal on my lg32lc5dc tv
Hd signal on my lg32lc5dc tv
Anonymous
Level 3:
Top Expert:
  • LG Master 14,553 Answers
  • Posted on May 22, 2012
Anonymous
LG Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715444
Points
48227
Answer a few questions to try to resolve this issue:
What is signal source for HD you are using? (cable box, sat box, receiver in line, antenna).
Where on the set are you connected? (HDMI, HD component input on rear or?)
Does if not a box used the set have a built in HD tuner?
Ho do i fix my lg32lc5dc tv
Download the user manual to your LG set from net, and check whether settings to HD reception has been set. To download the manual, click here.
4helpful
2answers
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
1helpful
It's staying on 480i sd why not 1080i
There's only one way to get that TV to switch from 480i (which is an SD or Standard Definition signal) - that's to provide it with an ED or HD resolution signal (a 480P signal is often called ED or Enhanced Definition while 720P, 1080i and 1080P signals are called HD or High Definition).
The old standard yellow composite video cable.
You will not get ED or HD signals through the old composite RCA phono jacks (usually yellow in color), either. You'll need to use an RGB (red, green and blue) component video cable, HDMI cable, DVI, or other type supported by both your TV and the video source (CATV box, Blu Ray disc player, Satellite converter, etc.). More on this, later.
RGB cable.
An HDMI cable - this provides Digital audio signals, too.
A DVI cable.
First, you'll need a source capable of sending ED or HD signals. This can be a progressive scan DVD, Blu Ray player, HD Cable or Satellite converter, or a simple TV antenna. Not all DVD players are capable of the 480P progressive scan output - it must be labeled as such. The DVD movies are not labeled progressive scan as they all will play back at 480P if played in a DVD player capable of progressive scan, otherwise they play at 480i. A stand alone Blu Ray player or one in the Sony PlayStation 3, the older HD-DVD in the Xbox360, (it is important to note that the Nintendo Wii can output either 480i or 480P signals only when connected with their special component video cable), "set top boxes provided when you choose HD service from your local cable provider or satellite TV provider are the main sources for signals better than 480i. As mentioned above, the old standard yellow video jack is not capable of supporting signals better than 480i. You must use the HD jacks and cables between to get these signals into your TV.
The Wii 480P cable assembly - includes stereo audio, too.
Lastly, if your TV has an ATSC tuner (it is not uncommon for it to have an NTSC tuner and CATV tuners as well), you can input a UHF antenna directly into the the antenna terminals on the TV. Broadcasters in most areas have been moved into UHF bands - but some areas have one or two that operate in the VHF bands still. Check antenna web for information and help selecting antennas and broadcasters in your area. The nice thing about the antenna method is that no other cables, converter boxes, etc are needed to enjoy HD signals - plus - they're free!
Just remember you need a source capable of ED or HD signals and a way to get those signals to your TV. The yellow composite cable is from days ago and only passes 480i signals.
I hope this helps and good luck! Please take a moment to rate my reply - thanks!
The Direct TV installer is on the way. What do I need to do to get this TV to receive HD? It says that it is HD Ready. Not sure what that means.
You dont have to do anything When your TV says it's HD ready it just simply means that it is waiting for your installer to run the HD signal to it through a cable. Then your TV is going to turn that signal into HD picture and audio. All you have to do is sit back and enjoy HD programing
4helpful
The hd tv keeps cutting out and saying no signal
It not the tv,u restart the Sky HD box the signal come back right?The Sky HD box is the problems,replaced the box,u will solved this problems.
I have a samsung LN52A550 LCD tv set and it won't show anything with a HD signal. If I hook up a 480I signal the tv will work,but if I hook up the tv antenna or any other hd source to it,the tv goes crazy...
Get a roof or digital antena.Will give u better signal.HD 1080i CBS,NBS check that if u have that in 1080i well able to get HD on the set.U might have a 720p tv set.
1helpful
Will my Mitsubishi Projection TV process HD signals?
the TV doesn't need to process the signal...the receiver will and send analog to the TV
HD TV
In order to receive HD signals, you will need an HD receiver from Dish Network. You can buy an HD antenna from pretty much any store that sells TV stuff (Target, Wal*Mart, BestBuy, etc) which will allow you to receive over the air HD signals. But in order to get your satellite channels in HD, you will need an HD receiver from Dish Network.
Tv picture
It seems to me that you are watchin an analog signal on a digital HD TV, the analog signal is has a standard resolution of 720x576 for NTSC (American Signal) and 720x480 for PAL (European Signal).
It could be worth to go contact your cable company, they can hook you up with a digital receiver which gives a better signal and might even have a HD Signal (this means it has a HD-Ready 1280x720 of Full HD 1920x1080 resolution).
If you really want to use your LCD TV on his max this is really worth considering
HD TV
Even if you have an HD television, it will not display an HD picture without an HD signal. Make sure you have an HD signal available and the television should automatically detect the mode and switch to it.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
