Maytag MDB4651AWS will not start. Control panel lights come on when cycle select button is pressed. Scroll thru cycle selections heavy & light cycles light up but normal will not. Purchased new electronic control panel, installed and symptoms unchanged. HELP!
SOURCE: Cycle buttons work, option buttons dont, Cant deselect heated dry, Wont start
I had the same symptoms and the front panel was the fix
the part with the buttons on it
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
SOURCE: My dishwasher control panel does not light-up
This is a common problem. I am about to replace my second control panel in two years. First time was under warranty and I hope this time will also e under warranty.
SOURCE: My Maytag steam dishwasher # MDBH980AWS won't do
My Maytag dishwasher # MDBH950AWW wont turn on no light but it has power in the outlet no power to the control board
