Replaced fuser, power supply, and main board. there was a low temp issue. replacing the main board fixed the low temp issue, but now i'm getting a HSYNC error code.
Its related to the LASER UNIT! When I had the problem I had the front cover off so it wasnt hitting the laser interlock switch which is located in the slot in the sheet metal on the front of the machine when the front cover is not shut........... If that makes any sense.
Printer error fuser tehp
I have one Xerox 3100MFP printer showing the same "Printer error Fuser temp" I have replaced fuser but same
xerox 3100 mfp error code (HSYNC)
i have the same problem wreby after replacing the fuser unit the machine is not working
