if the charger is ok then, visually inspect the batteries to see if they're bulging at allif the charger is ok then, visually inspect the batteries to see if they're bulging at all
You can't post conmments that contain an email address.
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
It's possible your battery is burnt out and the lights will activate back and forth as the sensor tries tell you its charged or not. You can take the battery and get it checked out where they sell that make of trimmer. have them install a new battery to see if that works for you. If that does not work its probably cheaper to buy a new trimmer.
Batteries don't always look degraded but if they've been in use for a while or have a bad cell, they will show up bad on the charger and it won't charge them. The only way to test the batteries is to try to charge them on another charger. If the batteries show defective on another charger, they are bad and you'll have to replace them. Also try to charge some batteries you know to be good on your charger to see if it's the problem. If your batteries charge on another charger, your current charger is bad and they don't have any replaceable parts in them so you'd be looking at replacing it.
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
