The messaging text is stuck on 'underline' with the little pencil symbol at the top of the screen. When I try to type text I can't select the correct letter from a key and just get a row of letters available on that key underlined. I've tried pressing the # key repeatedly to scroll through the options. This only alternates between caps or lower case, there is no longer an option for a 1st capital letter followed by lower case. The pencil/underline symbol remains in place. How can I switch this off please?
SOURCE: Text message function seems to be in some automatic word mode.
hi you are using the T9 dictionary on your phone to change settingsfollow these steps
1. go to messages
2. create new message
mow on the top left u will see a prcil with2 lies and abc written this means u are using the automatic dictionary function to change it press # button till u only see apencil and abc and no lines
now u can manually type words.
SOURCE: when I text I get an underline and I can't get
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
SOURCE: My phone crashed and now
which brand u use ? then get passward or install pc suite and connect ur phone to pc then operete ur phone as u like.
SOURCE: When I am texting,all the
You are currently enable T9 prediction.We can change this while texting by pressing # Or from "option" >>Prediction>>just turn it of.Good luck
