SOURCE: I have a LG LHT854 DVD Recever I need apoeration
Clicking here will download the manual (in a pdf form) for you:
http://www.lge.com/us/tv-audio-video/home-theater-systems/LG-home-theater-system-LHT854.jsp#
SOURCE: LG HDD/DVD player - navigational error message
HI,
DVD shrink can't handle the copy protection on the disk you're trying to backup, use DVDFab decrypter first instead.Get it here:
http://www.dvdidle.com/download/DVDFabDecrypter29.exe
Use DVDFab to rip the files to your HDD, it will create a VIDEO_TSfolder and put all the video files in it. DVDFab is a whole movieripper only, so you're getting everything on the disk ripped to you'reHDD, once DVDFab is done, run DVD shrink. Use DVD shrink to open thefiles created by DVDFab (use the open files tab and browse to theVIDEO_TS folder created by DVDFab and choose it), at this point shrinkwill import the files, use shrink as you normally would to create yourbackup.
thank you for using fixya,rate my answer,
vijay
SOURCE: I CANT GET THE TV SOUNDS ON THE PLAYER
Do you mean from a tv program? You have to have the device such as a cable box or sat go through the dvd player by an input cable such as composite, componet or through hdmi. Then select the aux or aux input using the input buttons.
SOURCE: dvd/cd ejects any disc installed
I have exactly the same problem. Have you found a solution?
SOURCE: can not switch to aux mode input whitout remote control
I WANT TO KNOW THE SAME MANUALLY SWITHCHING TO AUX
