Switch On
your PC/ Laptop and log in to windows. A 'System Restore' window will appear. Note: It is better if you could remember from which date you are
facing the issue, try to select a date prior to that date. The detail of that particular date should show "System
Checkpoint" and time on the right hand side box. Select that date.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click
'System Restore'
Here you will have to check "Restore computer to an earlier time' and
click Next
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '<' sign in the upper left hand
corner of the Month Calendar and select any date that you see in Bold.
Now, Click on Next and System Restore will start and windows will take a
reboot.
After reboot your problem should be resolved.
For solving pc problems live please visit: http://www.liveperson.com/computer-hardw...
SOURCE: Acer Aspire 4730Z- Keyboard not working?-can't enter the password
when upower up press F8 key then enter in safe mode.then clik on administrator
then u enterin winxp.then reset password or blakn
then try in noraml winxp.
it should autmatickly allocate the ram try taking out one module booting up windows shut down than put the other one in my acer aspire 4720z aka peace of **** only sees 1300 still so plez help if you figure how my email [email protected] plez
SOURCE: ACER ASPIRE 4730Z. How do I clear the CMOS (password)?
Below is the steps for clearing the password. Below that is the link for the manual, the picture of the jumper tabs is on pg. 153, good luck
Steps for Clearing BIOS Password Check
If users set BIOS Password (Supervisor Password and/or User Password) for a security reason, BIOS will ask
the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
• Power Off a system, and remove HDD, AC and Battery from the machine.
• Open the back cover of the machine, and find out the HW Gap on M/B as picture.
• Use an electric conductivity tool to short the two points of the HW Gap.
• Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
• Restart system. Press F2 key to enter BIOS Setup menu.
• If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password (Supervisor Password and User Password).
http://tim.id.au/laptops/acer/aspire%204730z%204730zg%204330.pdf
Testimonial: "Thank You"
