Compaq Presario Notebook Logo
Posted on Nov 24, 2008
CQ40-108TU XP DRIVERS
GETTING PROBLEM WITH WINXP/VISTA INSTALLATION
  • 2 more comments
  • masood_m_m Nov 24, 2008
    My Compaq CQ40-108TU came with dos. I want to install xp or vista but both fails to install.
    Kindly suggest as to what should be done
  • Anonymous Nov 26, 2008
    no drivers getting installed
  • Anonymous Dec 31, 2008
    My Compaq CQ40-108TU came with dos. I want to install vista ultimate but it fails to install.
  • Anonymous Jan 14, 2009
    same prob
M Adi
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 14, 2008
M Adi
Contributor
Level 1:
Answers
Questions
0
Helped
207
Points
I have found this from another forum hope it will work:
For Installing Vista, some users reported that after resetting the BIOS to default (F9), the VISTA installation running smoothly.
In your bios the information of "non vista os installed" is "the Factory installed OS" for this laptop. Probably, you bought this laptop with freedos OS.
I recommend you to install VISTA for this model, however, some users with their own reasons feel the need of XP as their OS.
Up till now, they end up having a hardware conflict between Audio and modem. Some of them can tolerate it, some still finding for the solution.
Unfortunately, they could NOT ask a help from HP/Compaq since HP/Compaq ONLY support VISTA for Operating System.
A policy that encouraged by Microsoft to FORCE users to migrate to VISTA
2answers
I want to change my pre-loaded windows vista on my dell inspiron 1526 to windows xp.
USE WINXP 'S BOOTABLE DISK ,GOTO BIOS ,SET YOUR BOOTING PREFERENCE TO DVD/CD THE SAVE USING "F10" PUT WINDOWS XP BOOTABLE DISK & FORMAT YOUR SYSTEM & LOAD WINDOWS XP.
WINDOWS XP & VISTA drivers
Yes you can dual boot any computer with vista and winxp.
Also you can user your web cam with winxp and vista.
Audio Problem in Sony Vaio VGN-SZ79MN
I think that all you have to do is to install the driver, reboot and go to your computers control panel.
Under "Sound and Audio Devices" on the "Sound" tab you only have to make sure your
4answers
Dear Sir, Have Dell laptop Inspiron 1525 with Vista loaded....but I need Win XP-2 OS on it...CD of which I have but don't have the laptop drivers compatible with XP. Can you pls guide me how & where to...
If your laptop is still under warranty, installing WinXP will void the warranty. It's very tricky. I'd suggest getting another PC with Internet connection and search and download drivers as needed for your 1525. Good luck.
2answers
Sound driver of winxp prof. for hp pavilion
Try this Link
It's for Vista but it may work.
Or this Link
It's older but dedicated for Win XP
2answers
Acer Aspire 4315
Yes you will get all the drivers here
http://support.acer-euro.com/drivers/notebook/as_4315.html
However only Vista Premium and Vista Ultimate users can perform a direct downgrade. You can start a fresh installation from a bootable disk of WinXP. Be aware that this will replace the Vista with XP.
2answers
I have a Hp dv2700 laptop,i wanna install winxp on it but when i m starting installation it,after first restart,I cannt select continueing installation win xp .
I havent encountered that issue before however if the OS for XP is even partially installed find and get a copy of EasyBCD and follow directions to add XP to the Vista Boot Record and then choose XP while booting and it may let you finish installation.
8helpful
13answers
2answers
Acer 5570Z audio driver no sound
Try searching on google for KB888111. It's a microsoft software that is for the HD Audio bus that corrects a lot of problems.  Run driver update and point to the software you downloaded for 888111 and then install the software for the audio.
2answers
I have a Memorex U48 Flat Bed Scanner and have bought a new compouter with Vista. I need a driver download to work with Windows Vista. Thanks [email protected]
get the winXP driver MEMu1.50 (still available), there are no Vista drivers. Run the installation using WinXP emulation in Vista. You must run the installation as if you are in XP, not necessary when using the scanner subsequently. Now the Memorex 48u works on a Dell Dimension, running Windows Vista Home Premium. Hope this helps. I got the scannner for $14 after rebates at Staples years ago, it won't die.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
