Don't think there are any free copies of the service manual but here is one for 10 dollars with instant download--no waiting.
http://john-deere.backupmanuals.com/John-Deere-GT275-Lawn-and-Garden-Tractor.html
SOURCE: I have an issue with my JD GT275. It won't start.
Hows the compression ? Has it been sitting ? It could have a stuck valve .What engine do you have ?Did you try putting a little gas in carburetor ? If so did it run a few seconds ? If so its a carburetor problem ! Remove and clean carburetor .You could also have water in gas this will cause the same thing you can look in the tank and if you see a bubble in the bottom its water needs to be cleaned out and bowl of carburetor also needs too be removed and cleaned,Try these and give me results,hope this helps !
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
SOURCE: Need a drawing on how to install belts on 48
Go here https://jdparts.deere.com/servlet/com.deere.u90.jdparts.view.publicservlets.HomeUnsigned
Sign up and you can access all available information on your tractor
SOURCE: John Deere 445 pto will not start Smoke from
If smoke is coming from solenoid on rear top side of trans then internal windings are bad but usually it will blow the fuse.Remove plastic nut from solenoid,slide solenoid off shaft then engage PTO.If solenoid does not smoke slide screwdriver or something like it into solenoid and see if there is any Magnetic force.If smoke comes from deck check idlers and spindles for movement.Be sure to ckeck gearcase oil level on the deck.
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
