You can get the Unlock code for Samsung Chat C335 using the unlock code..You can get the Unlock code from Mobile-unlocker.com/samsung-cht-335/rs2wp9/ and Unlock it easily...
SOURCE: my samsung chat 335 wont
Hi, issues like this are related to (network) problem ,
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vice- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message and mms message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive or send mms messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
SOURCE: theme for samsung chat 335
econo-soft.com/download/samsung%2Bchat%2B335%2Bthemes.html Hope this works for you! :)
