Dell Latitude D610 Notebook Logo
A
Anonymous Posted on May 19, 2012
Press Fn - X to return the system to normal running mode
Computer error message
goneforever.
Level 3:
Top Expert:
  • Dell Master 14,531 Answers
  • Posted on Dec 01, 2018
goneforever.
Dell Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263784
Points
66315
Charles wants answers to this question 2004 made PC,
hyjacks a 6 year old post, why not start your own post
with your facts.?
no OS stated, windows ? what?
is the PC dead, or only shows that error doing X
tell what X is, doing what.
the PC , is old. take out the big battery run on AC only pack
error still?
then CMOS coin cell is dead. if resetting bios fails.
read at Dell.com see what they do first,,,,
I think it means the PC lost power, in the wrong way.
or the 2 batteries in the PC are bad.
https://www.dell.com/community/Laptops-General-Read-Only/start-up-is-saying-quot-Manufacturing-Mode-press-Fn-X-level-01/td-p/4203860
5 Related Answers
Anonymous
  • Posted on Jun 10, 2010
SOURCE: As soon as I power on My Dell D610 in boot screen
As soon as I power on My Dell D610 in boot screen appear : '' MANUFACTURING MODE: LEVEL '67'''
''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'. This does not appear to work, it then shows hit F1 for shutdown, nothing happening with that operation either.
Walter H Boehm
  • 998 Answers
  • Posted on Feb 09, 2011
SOURCE: manufacturing mode : LAVEL (67) Press Fn-X to
This usually displays on the LCD when a motherboard has just been replaced. You need to hold down the key next to the space bar and the key to return to normal mode.
Anonymous
  • 188 Answers
  • Posted on Dec 21, 2010
It can be a possible hardware issue or a software issue
Try to run the dell diagnostics
http://findtechhelp12.blogspot.com/2010/12/how-to-run-dell-diagnostics.html
If it fails replace the part on which it fails.. If it passes reinstall the OS to fix the issue
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
Edde Jenkinson
  • 53 Answers
  • Posted on Jul 26, 2011
SOURCE: manufacturing mode: level (67) press
Sounds like a bad memory stick, or badly seated memory. Try opening the cover where the memory reside, take it out (gently) and put it back in. See if that fixes it. Try also pressing F12 as the machine boots up and go into the diagnostics menu. Test the memory to see if you have a failing memory stick. Laptop memory is quite cheap these days, so don't worry if the memory is faulty - it's easy to replace it.
benwabnick
Ben Wabnick
  • 2404 Answers
  • Posted on Nov 30, 2009
SOURCE: My Dell D610 in boot screen appear :
When the machines are put together at the factory they stay in factory mode until the tech presses the FN key and X key together.
Go ahead and do this so your machine goes into user mode and it should reboot then the message should go away.
3helpful
MANUFACTURING MODE :LEVEL [67]****** press Fn-X to return the system to normal running mode
press the fn button on your keyboard with the x letter ( press fn dont leave it and then press the x letter while u pressing the fn )
Hi I have a dell d610 and whenever I power it up it gives me the following message: '' MANUFACTURING MODE: LEVEL '67''' ''PRESS FN - X TO RETURN THE SYSTEM TO NORMAL...
Follow the instructions on screen in order to return to normal mode. Safest thing I would advice yo do is, back up all your important data from the hard drive onto an external hard drive and reset your notebook. this will remove the error message from your notebook. If you are able to, you should take your notebook to a qualified IT technician. I hope this helps you.
2answers
Manufacturing mode: level (67) press fn-x to return the system to normal running mode. the amount of system memory has changed.
Dell Latitude 810 will not boot. When computer is turned on a black screen appears with the message "Windows could not start because the following file is missing or corrupt: <Windows...
Boot to the WIndows XP CD (Press spacebar when prompted to press any key) at first prompt in setup, press R to enter recover console.
At the C:\Windows\System32\> prompt type bootcfg /rebuild then press enter
http://support.microsoft.com/kb/330184
reboot see if error resolved.
If not then try running diagnostics by pressing Fn plus power button, see if there is a HDD malfunction
3helpful
2answers
Manufacturing mode : LAVEL (67) Press Fn-X to Return The System to normal mode what is this please halp as
1helpful
2answers
Dell Latitude D610
This sounds like it might be some sort of virus or malware. Do you have anti-virus software installed? If you do, run a full scan of your system. Run it at least twice if nothing is found the first time. Windows doesn't typically tell you to press F1 to shutdown your computer.
If you don't have an anti-virus program installed, you can run the Windows Live One Care Safety Scanner from the web:
http://onecare.live.com/site/en-us/default.htm
2helpful
My Dell D610 in boot screen appear : '' MANUFACTURING MODE: LEVEL '67''' ''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'
Will not display output from Computer
Probably the video resolution or the monitor Refresh Rate (eg: 50/60/75 Hertz) is set too high in the operating system, which over-drives the monitor electronics and it is unable to display anything.
If you restart the computer manually (hold in the power button for 5 seconds, the computer will shut off, turn it back on again) you will see the normal BIOS and Windows startup display on the monitor, but then as Windows completes it's startup it returns to the error message you see.
To fix this, restart the computer manually and start the computer in Safe Mode. To do this press F8 just before the computer starts to load Windows, and choose Safe Mode. Once in Safe Mode, you should see the monitor working correctly.
Now restart the computer in Normal Mode and everything should be fine.
Notebook System Crash
Hey there SeanJohn79, have you tried hooking an external monitor to your laptop. You can move the video output back and forth, from external, LCD + external, LCD using Fn + F7. Hopefully this will allow you to see the necessary info for diagnosing the problem. Good Luck. Keep us posted! In case you are not aware, these are some display related key functions:
Fn + F3 = turn off lcd
Fn + F8 =Switch computer screen size
Fn + F12 =Hibernation mode, power for 4 secs releases.
Fn + F4 = Standby mode, press Fn key to return to normal
If you haven't tried switching some of these, give it a shot.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
