Juki MO-655 Mechanical Sewing Machine Logo
Posted on May 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My thread keeps ripping on my juki mo.2416 how can i fix the threading
Debbi's Sewing Machine Repair
Level 3:
  • Juki Master 7,365 Answers
  • Posted on May 21, 2012
Juki Master
Level 3:
Answers
7365
Questions
Helped
1744166
Points
19451
Try changing the needle
check for burrs
5 Related Answers
Anonymous
  • 208 Answers
  • Posted on Jun 27, 2009
SOURCE: THREADING FOR JUKI MO 357
Put new needles in it.
Following the colors, thread the upper looper first, then the lower looper. Next thread the needles. Always thread in this order.
Anonymous
  • Posted on Jul 16, 2009
SOURCE: I have a Juki MO 3716 and I cannot thread it. Please help. It has four threads.
I also own a Juki MO3716. It is a five thread not a four as it has three lower looper threads. Two are fed through the front, just follow the color codes and the threading diagram on inside plate that you lower to see the threads, the third is threaded through the back and around the left side. I can send email with picture of diagram if needed. the other two threads are for the two top needles. This machine is a true safty stitch with the overedge row of serging and an inner chain stitch row for secure seaming. You can run this machine quite nicely with only three thread ( one inside needle and the two front loopers. If you need further held email me at [email protected]
Anonymous
  • 47 Answers
  • Posted on Jul 24, 2009
SOURCE: Need a "How to Guide"
Visit us at www.ifixmachine.com
Anonymous
  • Posted on Dec 18, 2009
SOURCE: I want to have my Juki MO-2516n do a mock safety stitch/4 thread
I have a Juki MO 2516N. It does not have the capability to serge 4 threads. The only options are 2, 3, and 5.
trial2962
Val
  • 107 Answers
  • Posted on May 05, 2010
SOURCE: JUKI Garnet Line MO - 644D - How to thread ?
You might try on eBay items like 160431427159
My right needle thread keeps pulling out on my Juki 655 - how do I fix this?
make sure the top tension is not to tight
keep longer thread tails for 4 to 7 inches
keep the thread pulled behind the needle before you start sewing
see if that helps solve the problem
1helpful
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
2helpful
Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
Juki mo 2316 nEEDLE THREAD KEEPS BREAKING
I took my machine in to a place that fixes machines.
Thanks anyway!
2helpful
3helpful
5helpful
4answers
Instruction manual for the dressmaker 6800
goto ifixmachines.com they have your manual, just email them if you don't see it
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
