Motor runs fine until blades turned on, worse the higher the grass.
Sound like a carb problem clean the jets out
sounds like a safety switch problem .if you remove the the key switch and look at the back of the switch you will see letters the ither the backing or on the prongs the the plug gose on your looking for the one that has the letter M normaly there are two wires going to it and they alot of times are yellow one of them controlls all the motor kill safety one of them turns the motor off .follow them figure out what one connects to the motor .then clip the other one with a pair of cutters .start your mower then turn it back off if it dose not shut off you cliped the wrong wire .if so conect them back together and clip thr other .buy clipping the correct wire this will eliminate all motor kill safetys
SOURCE: I replaced my mower deck belt on my Husqvarna
There is a small brace that stops the clutch from spinning and ripping out the wires, i think you may have forgotten to put it back
SOURCE: Husqvarna zero turn mower won't start
Usually if all you hear is a clicking noise, it is the solenoid itself that has gone bad...if you can jump the solenoid and the mower turns over, it is the solenoid.
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: My husqvarna zero turn mower has an auto safety
There should be a switch under the seat. The system is designed to stop all functions if no one is setting in the seat. I believe the seat switch has failed.
Check it out and let me know.
Regards,
SOURCE: I have a Husqvarna Yth 180, the lawn mower shut
try unplugging the pto then start the mower next engage the blades and see if the fuse blows if it does the problem lies in the mowers wiring if not the problem lies in the pto. hope this helps
