Singer 7422 Logo
dianka Posted on May 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Start sewing and starts beep say e2
It's so annoying and it won't stop beeping i don't know how to fix it please help
Cindy Goyette
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 05, 2015
Cindy Goyette
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
506
Points
My singer sews but when I go to wind the bobbin it starts beeping help!!!!!
Debbi's Sewing Machine Repair
Level 3:
  • Singer Master 7,365 Answers
  • Posted on May 21, 2012
Singer Master
Level 3:
Answers
7365
Questions
Helped
1742653
Points
19451
Try rethreading the machine top & bobbin
clean under the needle plate & in the bobbin area for loose threads or lint
try changing the needle
5 Related Answers
Anonymous
  • 27 Answers
  • Posted on Jan 10, 2009
SOURCE: Wont Start (brand new) Just Beeps!
make sure the bobbin winder is not engaged and thread the machine over ,also check that the buttonhole switch is not down
Anonymous
  • Posted on Nov 12, 2008
SOURCE: The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
A
Anonymous
  • Posted on Nov 03, 2008
SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Anonymous
  • Posted on Apr 17, 2009
SOURCE: machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
Anonymous
  • Posted on May 24, 2010
SOURCE: The machine is beeping and does not start. It
Is your button hole lever down? I had the same problem after sewing a button hole and couldn't figure out why I couldn't return to normal sewing. Once I raised the button hole lever the machine worked again.
2answers
Janome dks 100 se - it keeps beeping when I press the foot pedal and I have to do this several times before it starts sewing. It doesn't beep when using the stop/start button and is sewing fine
Same machine and model and same problem. It’s really irritating. It’s not the bobbin as the screen flashes worth the foot pedal. I’ll look at the tension but given how often it beeps and on so many different projects with different thread and tension it seems to be a fault of some kind... searching for a fix...
I get an E2 error on my Brother CP7500 and the button lever is all the way up
A stitch other than the buttonhole or bar tack stitch was selected and the foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) while the buttonhole lever is lowered.
Raise the buttonhole lever before continuing the operation.
Each time a key pressed or an incorrect operation is performed, a beep is sounded.
  • For a correct operation
    One beep is sounded.
  • If an incorrect operation is performed
    Two or four beeps are sounded.
  • If the machine locks up, for example, because the thread is tangled
    The sewing machine continues to beep for four seconds.
    The machine automatically stops.
    Be sure to check for the cause of the error, and correct it before continuing to sew.
reference: http://support.brother.com/g/b/faqend.aspx?c=us_ot&lang=en&prod=hf_es2000teus&faqid=faqh00000059_000
user guide:
http://download.brother.com/welcome/doch000470/bc21es20cs60ce50ex66xr6677ug10en.pdf
quick reference guide:
http://download.brother.com/welcome/doch000566/bc21es20ce50qg02enfresdeitnlru.pdf
Singer confience stylist beeps four time and won't let me sew
The beeps usually indicates that your machine is not ready to sew which probably means a function has been left in the activated mode, ie bobbin winder, buttonhole function, etc. . Here are some ideas:
Why does the electronic beeper beep and the sewing machine won sew Sewing...
20 Most Recent Singer 7467S Confidence Stylist Electric Sewing Machine...
E2 error code brother sewing machine
Note Each time a key pressed or an incorrect operation is performed, a beep is sounded.
  • For a correct operationOne beep is sounded.
  • If an incorrect operation is performedTwo or four beeps are sounded.
  • If the machine locks up, for example, because the thread is tangledThe sewing machine continues to beep for four seconds.
1helpful
2answers
My singer curvy starts beeping and lights flashing and won't sew
I just got mine to stop flashing lights and function again when I unplugged the cords from the machine and let it sit for a minute. You can always give that a try.
1helpful
Sewing then beeing then jamming up
The Beep is an alarm telling you to stop sewing and find the problem. Since it is jamming in the bobbin area, you should start there. Remove the fabric, then remove the bobbin and bobbin carrier... clean and remove any stray bits of thread from the bobbin area. You also should examine the needle or change it as a matter of course.
Machine starts beeping and stops sewing everytime I try to sew
Ok, first of all never do that trying to force it to work thing. It is beeping because there is a problem. Stop... unplug it, remove your work and discover what is wrong. (Likely that you've got thread under the bottom of the feed dogs ... but it could be something entirely computer related... since these are computers... they don't like extreme heat OR cold.
1helpful
2answers
Singer confidence 7463 all lights flashing
try
clean under the needle plate & in the bobbin area for lint or thread
make sure bobbin is inserted correctly & that it's not damaged
2helpful
4answers
Singer curvy beeps 4 times and stops sewing
when you thread the machine make sure to use every thread guide
check to see if the bobbin is in correctly
try changing the needle--normally flat side goes to the back
the needle that your sewing with is it the right one for the thread & fabric
clean under the needle plate & bobbin area for lint or loose threads
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
