Just purchased a Hamilton Beach Microwave Oven and the turntable doesn't turn.
SOURCE: i have a microwave oven i purchased
Remove the glass turntable, then the roller ring. Then seta glas of water in the unit and turn it on for 5 to 10 seconds. Look through the door window and see if the drive hub is rotating. If it is, then check the underside of the glass table to match up the drive hub. If it isn't turming, the drive, then it is internal and should have a 1 yr warrantee minimum. Remember, the, the turntable and drive must engage each other and the roller ring in place. Good Luck, and let me know please. One more thing, make sure there isn't a Turntable on/off swirch set in the off position. Good Luck, Ne
SOURCE: Microwave oven light stays on and turntable keeps turning
It would appear that relay # RY1 is stuck on your control circuit board.
We regularly repair such control units for
customers nationwide by mail for $39.95 postpaid in about a
week or so with a one-year guarantee.
We have
the service / repair manual for this model and have uploaded it to our
site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
We're happy
to help you. Once we have all your information and
offer a final solution, we'd appreciate your
thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: Microwave oven does not heat anything
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
SOURCE: how do i turn the turntable off?
You dont.
You can use spacers(nonmetalic of course) to raise the platter high enough to disenguage the drive. You can also shift the tray to one side on some models.
SOURCE: Ewave OTR Microwave Oven, Model KOT-153UW. Light
We see (and repair) this
a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a
week or so.
At
our Web site, you can get details of our service, plus we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
This light failure often
occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
The lights can can be
inoperable or stuck on or no bright, too. Sometimes this will similarly
affect the exhaust fan operation or inside light, too.Feel free to contact me directly (and please remind me of your
We're
[email protected]
