I'm assuming that your machine is not booting properly. You will need to place your disc Windows disc insert it then go to repair see if it will repair the boot manager again. Or simply re-install the original software that came with your machine again. You may need to do this again. These are usually indicators that tell you it is time for a total reboot of your system not always but in most cases I have worked with over the years I usually advise my clients to re-install system all over again to get rid of registry errors or add ware or spyware that has been installed to create this mess in the first place.
This is why it is so important to keep up with the cleaning of your system and data storage off of the hard drive. Just in case these things happen and they do. So if you have not already done so and hopefully you have not lost any important data thus far If you still can get it off that machine right away and re-boot or do a boot repair from the Windows original software that came with your laptop.
I have this gave you some sort of idea as to what I would do if your machine is right in front of me. John
