I have been given a newhome 532 Sewing machine and a couple of days ago it worked fine. I come to using it today and now it will not sew. Please help
You said the machine was given to you, has the machine ever been serviced that you know of?
is it making stitches?
how is it not sewing?
SOURCE: The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
SOURCE: ELNA 7000 SEWING MACHINE
If you bend over the front of the machine, you will see a slider switch on the back of the machine, and there is a small "button" at the bottom right of the switch (your right). If you push this button down, you can slide the slider switch to your right and the feed dogs will go up.
SOURCE: I can't find the manual for White's sewing machine with model 675
The folks at White sent me this reply to my request for a manual.
Thank you for contacting White. Unfortunately the instruction manual that you have requested is no longer in print.
We do however, have a free copy that you may download from our sister company "The Singer Sewing Company's" website.
To download your free copy of your "White" manual, please follow these steps:
1) Go to www.singerco.com
2) From the "I am looking for" drop down menu, select "Instruction Manuals".
3) To find your particular manual, enter W and then your model number (W1600) in the search box.
4) Click on "Search".
The manual is 31 pages, in pdf format.
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
SOURCE: need manual for newhome triple zig zag model 888
they are available at http://ifixmachines.com/Janome-Model-M888/Janome-owners-manual-M888/ilvm_fly1_black.tpl.html?keyword=888
