Nikon D5100 Digital Camera with 1855mm lens Logo
Hussain Posted on May 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon D5100 vs Nikon D3200
Here are my interests below 1- very high image quality 2- will be used family photos and children 3-I'm fast learning new stuff 4- never had slr in the past Please advice me
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on May 19, 2012
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442339
Points
622693
They both take superb pictures. The D3200 is slightly easier to learn how to use, while the D5100 is easier to use once you learn it. That is, the D3200's menus will guide you through all its settings, while with the D5100 you can change those settings with less work once you learn the proper buttons to push. The D3200 has a higher resolution, but even the D5100 will take photos that can be enlarged to 8x10 and larger.
I suggest you go to a good camera store and try them both out. See which one better fits your hands. You don't want to buy a camera based on specs, or other people's opinions. You want a camera that best works for YOU. Having said that, the D3200 is probably a better first SLR. However, try them both out and choose the one that's better for YOU.
5 Related Answers
Anonymous
  • 477 Answers
  • Posted on Apr 17, 2008
SOURCE: Nikon Coolpix L11 - LCD screen shows double image
It could be a loose LCD connection carefully take off the back and lift the LCD very carfully you will see the ribbon cable lift the tab take out the LCD and reinsert it and push the tab back down. If this does not fix it you might have a damaged main board its one or the other.
Anonymous
  • 14 Answers
  • Posted on Apr 11, 2009
SOURCE: Can't take pictures in low light/no flash with my Nikon D40X
First of all you need a tripod to cut down on the movement . Next use the mode dail and select a nigt setting .
You can even use a shutter speed in Aperature Prioity .Ypu might want to use exposure comp .
This should work for you.
Anonymous
  • 65 Answers
  • Posted on May 09, 2009
SOURCE: can you use nikon sb25 flash with d40 dslr?
You can but with limitations;
Save me explaining,please read this http://forums.steves-digicams.com/nikon-dslr/137618-sb-25-d40-non-ttl-auto-mode.html
HyeProfile
HyeProfile
  • 35 Answers
  • Posted on Aug 05, 2009
SOURCE: Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
Jeff Marcus
  • 115 Answers
  • Posted on Sep 28, 2009
SOURCE: My Nikon D40 won't take pictures fast.
There is a buffer in your camera that processes your images for storage on your memory card. The larger the file size, the more the buffer is being used per image. That will slow down your image transfer.
Also, memory cards are not just about the size of the memory card. It's very about about transfer rate. Once the buffer is ready to send the image to the card, the card has to be able to accept the MB quickly. If your card has a transfer rate of less than 255, it's going to be slow, especially with larger images.
Nikon D5100 wont flash
Here is a list of things to check:
1. Go into the camera's menus and make sure that the flash is enabled.
2. Check in the menus that the flash is not set in the command mode.
3. You didn't say if your camera was in the auto mode, aperture or shutter priority, etc. If the camera is in shutter priority or manual mode, make sure that the shutter speed is below 1/250th of a second.
4. Make sure that the ISO speed isn't set so high that the camera thinks that flash is not needed.
Which is best the wu-1a or the wu-1b for a nikon d5100?
Your camera can't use one of these wifi transmitters.
According to Nikon, you only can use the wu-1a with a D7100, D5200 and D3200 and a few other(very modern small camera's)
The B is for the D600. and some camera's from the 1 series.They are not mentioning camera's that are in production for more than a year.
Want to see the shutter count on the used Nikon D3200 I just puchased
I couldn't locate the specific info requested but here is a link to the manual for the camera. Hope it helps. Good luck
http://www.nikonusa.com/pdf/manuals/dslr/D3200_EN.pdf
Zoom on nikon d5100
In either mode, you're zooming by turning the zoom ring on the lens? In live view mode, if you zoom in by pressing the magnifying glass button, all you're doing is zooming the display, not the image itself.
Which camera of canon KissX5 and Nikon D5100 would you recommend for a first time user?
Neither. For a first-time user I'd recommend something easier to learn to use, either a Canon Kiss X4 or a Nikon D3100 (not the D3200). You aren't really giving up any features, but getting something a bit easier to learn. And saving a little money.
In a year or so, when you're more comfortable with the camera then you might consider moving up to something more powerful. By then any current camera will have been superseded by something new.
1helpful
Went to a camera class a couple of months ago to learn how to use my Nikon D3000. We made a lot of setting changes. Now when I download photos, I get 2 copies -- a jpeg and an nef file. Do I really need...
In some ways the NEF file is the equivalent of a negative, while the JPG file is the equivalent of a print from a negative. However, since digital copies are exact, you don't need the NEF file if you're not going to do anything fancy with the photos. I know people are going to argue with that --- heck, I'm one of them, I shoot only NEFs.
Press the info button to display the information display, then press the i button to put the cursor in the information display. Use the multiselector to highlight the current image quality setting (the topmost item on the right side of the display) and press OK. Select JPG fine and press OK.
For full details, see the "Image Quality and Size" section in the manual (page 50 in my copy).
2answers
Poor quality images outdoors
try setting your camera's auto balance into Automatic or Outdoor. So the camera could adjust the light or diable flash.
2answers
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
