Remove the side pane to access your motherboard cables, etc. Locate the
connector on your motherboard that contains the wires going from your
power supply to your motherboard. It will be a large, rectangular
connector with a lot of individual wires It is not a ribbon cable but
should be located next to a ribbon cable connector and next to a green
blinking light on your motherboard (when the power supply is plugged into
the wall). Note: This green blinking light is in addition to the
green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted
above from the motherboard WHILE the power suply is plugged into the
wall. Wait a few seconds and plug it back in. The blinking reen light
on the motherboard should now be a solid green light. The PC should now
power up.
If the steps above don't work you will need to get a new power supply.
haha. i was trying to search for the question and accidentally posted a question. what is even more funny is i did what you said even before i read your solution. but thats what worked haha. thank you
