SOURCE: I bought a coby tablet
It might be the version of the Android on it. If you use Android 2.1, then you have to upgrade it to Android 2.2, then you will be able to play Flashcontent.
But bad news is, that you have to wait, until Coby releases an Android 2.2 upgrade for Kyros (http://www.androidtablets.net/forum/coby-tablets/3663-coby-kyros-7015-tablet-questions.html), because if you upgrade your tablet PC from elsewhere, then it might be malfunctioning.
SOURCE: would it be possible to
You can download the manual from the manufacturer's web site at
http://www.cobyusa.com/files/manuals/MID7015_MN.pdf
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase
Everything"
The following will occur:
• The screen will display COBY
• The screen will display Android
• The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target.
Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home".
The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until:
1- You have configured your Wi-Fi
2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
SOURCE: I got a coby tablet MID7015 and I don't have the code to unlock it.
If your device is in USB Debugging mode, your adb server may be in some wierd state on your computer. From the command prompt (from the \android-sdk-windows\tools folder), type adb kill-server and press enter. Then type adb start-server and press enter.
Hopefully this will help!
