Question about Pyramid Audio Players & Recorders
Pyramid pr 6700 equalizer manual
Pr-6700 wiring diagram
2 Suggested Answers
SOURCE:
marsrover
  • 682 Answers
SOURCE: installing pyramid 795cd equalizer
cd player or dvd player output------------to equalizer input---------equalizer output---------amplifier input--------amplifier output ----------to speakers
Posted on Dec 04, 2009
Epiphone wiring diagram pr-5e
Your best best is to contact Epiphone Customer Service. Generally they're quite helpful. Here's a link.
Feb 11, 2015 | Epiphone PR5-E Electro Acoustic Guitar...
Can you show a diagram for threading the PR 650 Brother embroidery machine
Have you tried looking on www.youtube.com ? There may be a video there, OR, try the Brother website.
Feb 10, 2015 | Brother Entrepreneur Pr 650 Embroidery...
Wiring For Gateway LX6200-01 Motherboard
You might be able to get a MB layout diagram from Gateway
Jul 26, 2013 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
Those elusive manuals...
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
May 19, 2012 | Pyramid Car Audio & Video
I have installed a PR 180 at the top of the basement stars to turn on the light when someone enters, and a normal 3 way switch at the bottom. The idea was the lights come on when you step into the...
While there are many ways to wire 3-way switches, the most common way is to bring a 2-wire/with ground HOT and neutral cable (from circuit breaker or source) into one switch box and a 2-wire/with ground LOAD cable (to light) into the other switch box. Then a 3-wire/with ground cable is ran between both switch boxes.
The PR 180 _must_ be installed at the switch box the has the cable that goes to the LOAD. I suspect that you have the PR 180 installed in the switch box that contains the HOT feed.
Unfortunately, the solution is to install the PR 180 at the downstairs location and have the normal 3-way switch at the top.
Another solution would be to install a Leviton 1PP15-1L at the switch box that has the HOT feed and a Leviton 1PP0R-1L at the switch box the has the LOAD cable. This, of course will result in a sensor at each location.
Aug 20, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
I need the wiring diagram of Voltas AC remote control Board GAL0409GK-01
Sir me ek volt as spirit ac kr RHA hu problem ye he outdoor indoor chalne PR phele 8 for 22 amp ho jate he only outdoor PR normal amp he men's indoor ki motar change or do PCB change or do Magyar who problem he pls btaye out door ki wait hats or indoor OK he only out for cha lane she out for OK he
Jan 23, 2010 | Heating & Cooling
Need wiring diagram for a carrier 383kav11048075? im replacing the icm281 control module. gas furnace
There should be a wiring diagram on the panel of the furnace. In the box of the icm 281 is step by step instructions.
Maybe this will help
Take notes on your low voltage wires from the thermostat and condenser. W Y R C G. Write down what color wires go to above terminals.
On your high voltage wiring,
Take the black wire from the transformer and put it on PR-1.
Take the white wire from the transformer and put it on PR-2
Take the black power wire from the panel interlock switch and connect it to L1
Take the white neutral power wire and connect it to L2
Take the black fan motor wire and connect it to HI
Take the red fan motor wire and connect it to LO
Take the white fan motor wire and connect it to COM
Then reconnect your low voltage terminal wires to W Y R C G.
Thats it.
May 03, 2009 | Carrier Heating & Cooling
Bought two pairs; not communicating with each other
Hi
If the second units are not working check power in those units, ar eyou sure they are on the same channel? also make sure the antennas are connected correctly.
good luck,
John.
Dec 20, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
107 people viewed this question
Top Pyramid Audio Players & Recorders Experts
 Grubhead
Grubhead
protojexxx
Dave Cowley
Dave Cowley
Level 1 Expert
Are you a Pyramid Audio Player and Recorder Expert? Answer questions, earn points and help others
