HP Compaq ProLiant ML350 G3 Server Logo
Rakesh Posted on May 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On board leds are red in colour
No display
Venkatesh Kulkarni
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 181 Answers
  • Posted on Nov 14, 2013
Venkatesh Kulkarni
Expert
Level 2:
New Friend:
Cheetah:
Answers
181
Questions
0
Helped
51520
Points
214
Replace PowerSupply
Sony model HP212M83 picture quality colour problem is eastmen, (red soil colour) red light blinking 5 times, please.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
LLoyd. Why doesn't it turn on?
If the led is red that means its stuck in stand by mode which is an indication that you have a problem in the power board
Panasonic TH 42PA25. Front power switch LED is solid red. SC Board LED (D6583) is not lit. SS Board LED (D6765) is not lit. However, SS Board LED D6769 is lit. I suspect PA or P board.
The TV is on standby mode due to protection; some error in the board. If you have spare boards, try replacing it one by one, starting from display board.
1helpful
HOW TO CONNECT AHDD LED IN ASROCK MOTHER BOARD
Just parallel to Power LED button you find HDD or IDE LED button, the red coloured wire should be top and the white coloured towards reset connection.
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
6helpful
3answers
Code E05
E05 and E06 is the error codes for a faulty stack flue sensor. try changing the sensor first is the cheapest. if that doesn't work check for corrosion on control board in which case will have to change out board.
Wot colour should the guage on my bmw 316 be wen needing changed
Gauges reads as follow
Green LED = The fewer displayed closer to next service
Yellow LED = In conjunction with OIL SERVICE service or INSPECTION comes on when next routine service is due.
Red LED = a routine service is overdue.
Clock symbol in conjunction with INSPECTION = shows that an anual inspection is due.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
